Rear axle removal
Hey guys, need a little help here. I have my 69' C10 on the jack stands and I'm about to remove the entire rear end off the frame. I've been told to use the spring compressor, I've been told that I don't need one.
I know some of you guys are great in giving step by step process for different tasks. So here I am asking for help for removing my axle. I know it's simple enough and straight forward, but I don't want to overlook anything and get a spring drilled into my noggin. Thanks, Brian |
Grandpa in the rustmobile...
Re: Rear axle removal
The rear axle as in the chunk and all?
Soak EVERY NUT IN PB BLASTER Go back inside to get a snack or something loosen U bolt nuts (will need HUGE braker bar/pipe) Take panhard bar off Take brakeline loose from the front of the T fitting on the pass. side of axle Take parking brake calbes loose Loosen coil spring perch on the bottoms (I left the tops alone when I did mine, just let em hang Thats it I think, Good luck
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#3 | |
Thanks again, and I'm sure I'll be picking your brain again if you don't mind. Cheers, Brian |
Big Red - Now its a SWB!
Yep, if the axle is hanging (frame on jackstands), then there is no tension on the springs. Just put a jack under the pumpkin and take everything loose then lower the jack and the rear will come down. penetrating oil....and lot's of it is your friend here, the longer it soaks the better. Also when you put it back together use new U-bolts and nuts. Good luck, and eat your wheaties, you'll need the strength!
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Yeah order some U bolts
And if you think you may wanna lower it in the future get a drop block/ u bolt kit or something ![]()
Restoring it $200 at a time...
Come back on Sunday and we'll tell you how to remove the u-bolts that are rusted into the trailing arms.
![]() ![]() Good luck.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
Thanks for the tips guys! It dropped right out, and after fighting with it for a while with a 1" impact and a 5' breaker bar, I decided to work smarter. I decided just cut off the U-bolts.
#8 | |
![]() Join Date: Jan 2009
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
