Old 12-15-2010, 11:43 PM   #1
camaney
Starter not working
I change my tranny & now my truck is not starting. Battery is good headlights horn works and still don't crank or the solinoid makes any cliking sound. Check where the yellow wire goes in solinoid it gets full voltage key on the purple is very dim with key all the way. I try this on all gears(prn123) Also I try to jump yellow side to purple and nothing happen. Don't know what else to check
camaney is offline   Reply With Quote
Old 12-16-2010, 01:08 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Starter not working
try jumping the purple to the battery cable. Jumping the purple to the yellow shouldn't do anything at all.
If it turns over with jumping battery cable to purple, then you have an issue somewhere between the key and the starter.
Old 12-16-2010, 02:03 AM   #3
camaney
Will do that tomorrow. Now is it normal that purple wire it's so very dim realy hard to see?
Old 12-16-2010, 10:25 AM   #4
Lee H
Lee H's Avatar
Transmission change from what to what?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-16-2010, 10:28 AM   #5
cdowns
cdowns's Avatar
i'd check the connections for the purple wire on the neutral safety switch
Old 12-16-2010, 05:24 PM   #6
camaney
From th350 to 2004r . I check the wires by the neutral switch and I got good light on the key side but on the solinoid it's still dim should I replace the neutral swtch?
Old 12-16-2010, 05:33 PM   #7
Longhorn Man
if you have full voltage going in and out of the switch, then the problem is downstream of the switch.
After thinking about this some more, i wonder if the purple wire didn't get pinched between the engine and trans in the swap.
Old 12-16-2010, 05:45 PM   #8
camaney
Fix it. I took the neutral switch off and clean it real good. wires too put it back and it work. Thanks everybody
