Project black-ops
I have wanted a 1970 C10 for 10 years now. I finally made the decision to go for broke and find my truck. I live in Utah, so finding a rust free truck under $10,000 is about inmpossible. I searched far and wide for months before finally finding my truck in Bellevue, Nebraska. I got a great buy on the truck, so I convinced my buddy Mike to go with me on the 2 day journey to get it. Outside of Cheyenne, Wyoming we got caught in a hail storm that destroyed Mike's Duramax. Luckily his insurance company took care of the damage or I would still feel bad. It was quite an adventure getting to Nebraska but finally I loaded up my dream truck and came home to Utah. We pulled it home on a trailer because the previous owner (Rick) said it had been sitting for a few years in his garage. Rick built the truck for the track and the engine and transmission only had 500 miles on them. I purchased the truck for $7000 dollars which I feel was a steal. There is a little rust starting to show on the bottoms of the doors and the passenger floor brace. The truck fired right up and runs like a champ. This truck will smoke the tires right off the rims if I am not careful. The transmission shifts way hard and about throws my poor wifes head through the back window, but remember it is a work in progress. I wanted to start a build thread so I can share my passion with everyone on this board. Heres a little info about the truck I have found out:
1970 Chevrolet C10 2WD SWB (All this information is from the previous owner who put a lot of time and money into the truck before I bought it.) Previous owners: Cape Gerardo MO, Wentzville MO, Lake Saint Louis MO, and Bellevue NE Engine: Engine Block Casting Number: 3970010 (1968-1979) 2&4 Bolt Main Truck Hi-perf The engine was carefully engineered to be a street-able 375-400 hp The engine was blueprinted and balanced with 9.5:1 compression. The heads were opened up to 2.02 intakes 1.86 exhaust with hard seats installed so that pump fuel can be run. Heads were ported and smoothed. The engine had a high lift cam installed (5/8 race cam) 1:1.5 roller rocker arms installed. The timing chain is a double roller. The oil and fuel pump is a stock Z-28 spec unit. Intake is a Holley 750 double pumper vacuum secondary’s. Long Tube Headers New heavy duty 4 core radiator Transmission: TH 400 Rebuilt 3,500 RPM Stall Converter Transm (shift kit added) Suspension/Drive: Springs were replaced with stock ones. A frame bushings, Ball Joints and tie rod ends were all replaced. 12 Bolt Rear End with stock Posi Track New U-Joints Balance Drive Shaft Brakes: Brake cylinders were rebuilt Rotors were turned and new brake shoes installed. Master cylinder was replaced Used power booster was added to give the truck power brakes. Body: Rocker panels replaced Moldings removed and holes filled Stake pockets welded up Body stripped to bare metal All body filler removed Truck was primed and painted with 8 coats of enamel black 4 coats were buffed off to create a clear coat shine Bed was sprayed with enamel clear coat Interior and under hood was painted New front bumper New rear bumper Interior: New door moldings New windshield New cardboard tank cover New glove box cardboard New duct work New rubber floor mat New dash pad Seat was recovered |
Re: Project black-ops
nice truck ,great story its always good to drag that truck home for the first time
C-10 Club Member
Looks like a nice solid truck with some extra goodies....
![]() ![]() What are the plans? BTW...I had to drive to utah to find my solid truck...haha ![]() ![]()
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
Cole,
Funny you found my thread! I have read yours from start to finish. I grew up in Kanab, Utah, very close to where you found your truck. I just ordered my front disc brake kit from ECE. I stayed with 6 lugs just like you did. I also ordered the 4/6 drop kit from ECE. I have my new wheels in my garage also, but I am waiting until spring to put my tires on. I went with the Summit Racing Legend 6 classic Torq Thrust look. I am planning on pulling the motor this year and re-painting it chevy orange, with new Pro Form valve covers. I am also going to dress it up with some chrome here and there. The exhaust needs done so I will throw on some Sanderson CC10 headers along with a full magnaflow dual exhaust. I need to dress up the engine bay a little while the motor is out. I bought the rust converter kit from Eastwood, along with some of their black frame paint so thats in my plans for spring also. I will eventually put new interior in the truck. I have plans to keep it black, but put a new paint job on it. It looks great, but it has no clear coat and I want to make it my own. I have considered going two-tone, but the last owner spent a lot of time smoothing up the factory trim holes and stake pockets. It has lots of small cosmetic stuff that needs done, but overall its a clean truck. Keep in touch and I will follow your thread as well. You and Nate have done a great job in detailing your work. |
#5 | |
C-10 Club Member
![]() ![]() Hard to go wrong with that drop/wheel combo. Keep up the good work I know I have about a million things I want to do to the truck and most are hindered by my lack of $$$...lol
We are building a house so my truck might be on the back burner for awhile. I want to get my headers and exhaust on soon, but we will see how the house goes. Even when you start with a clean truck it can nickle and dime you to death.
Decker looks good in his future truck!
I can only hope mine looks that good when I am done. LOL Very nice truck to start with.
70 Chevy SWB Fleet Project. 06 Lancer Evolution MR SE, stupid fast! 03 Ford f-250 crew cab, 6spd, diesel 56 ford f100 project My build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=426739 |
VA72C10
![]() Join Date: Mar 2008
very nice start! awesome truck!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Tot Roddin'
Diggin' the project and the plan you have for it.
My FIL installed a set of the Sanderson Headers on his '69 and they look and perform great! Be sure to keep us posted on your progress.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
I finally got around to pulling my truck in the shop and putting on my ECE disc brake upgrade, and the 4/6 drop kit. I could not believe how good it turned out. ECE makes very high quality parts, and I will do business with them every chance I get. The kit went on pretty easy, with the help of my good buddy Jeremy. I will not post too many pictures of the install since you can go to project blankslate like I did for helpful tips. I will have to do my exhaust sooner than expected, because my long tube headers are about 2" from touching the ground. I sent back my 17" wheels and upgraded to the 20's. I hope to have them on in the spring. My truck does not see any winter driving here because the salt would take a toll pretty fast. I also painted all the brake components with Eastwood Disc Brake Gray paint. Heres a few before and after pics.
VA72C10
looking good!!!
I have a set of stock springs out of this truck I would sell if somebody is interested. They were replaced when the truck was built about 10 years ago and seem to be in great shape.
Tot Roddin'
Much better...
#15 |
I finally put the new wheels and tires on this weekend. I went with TOYO PROXES ST II tires. 295/40/20 on the back, and 255/40/20 on the front. I wanted to keep a classic look, and the six lug, so I went with the American Racing AR 604 Torq Thrust wheels. I could not be happier with the look of the truck. The disc brakes make a big difference in stopping power also.
#16 |
'67 C-10 LWB Driver
![]() Join Date: Dec 2010
looks great!! sweet ride!
'67 C-10 LWB - My Build Thread ![]() '67 C-20 LWB - My Donor/ Parts truck - SOLD! '92 GMC SAFARI VAN - My Parts Go Getter '06 KIA SPORTAGE EX - My Commuter "All of this crap better make a truck!" - my wife Sue. Proud U.S.M.C. Dad! |
#17 |
VA72C10
Looks awesome! Love the torque thrust ST's (6 lug) Had a set myself but never got around to finishing the project so I sold them.
Yours is only the second 67-72 and first 70 I've seen with them on!
#18 |
Here is some updated pictures of my engine bay makeover. We are painting the engine with POR 15 Chevy Orange Enamel. I am in the process of installing a 700R4 as well. Here is the list of new parts going on the truck:
PROFORM ORANGE SLANT EDGE VALVE COVERS TAYLOR SPIRO-PRO IGNITION WIRES HOT ORANGE EDLEBROCK PRO-FLO AIR CLEANER CHROME LOGO FRAM AIR HOG AIR FILTER SANDERSON-CC10 HEADERS CHROME PULLEY’S BILLET DIP STICKS MADE FOR YOU PRODUCTS VERTICAL WIRE LOOM KIT 700R4 TRANSMISSION W/ COAN 3500 STALL TCI 700R4 TV CABLE CORRECTOR KIT KUGEL KOMPONENTS SHIFT LINKAGE EARLY CLASSIC ENTERPRISES TRANSMISSION CROSSMEMBER FUTURE: MAGNAFLOW DUAL EXHAUST (If my wife lets me)
BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=436046 |
#19 |
C-10 Club Member
nice....your really going for it!!
#20 |
Finally finished up the engine this weekend. I tried spraying plastikote chevy orange on the engine and it was like orange tinted clear coat. I ended up taking the paint off with aircraft stripper. I think I might have lost some of my skin in the process. I decided to go with POR 15 brush on paint and it turned out really nice. I installed the 700R4 and now I have to wait until I can save enough money to put on my magnaflow exhaust. I have a guy coming to the house tonight to measure my driveline so I can cut it and install the new yoke. I added a ton of new parts I have collected over the past year, and I couldn't be happier how it turned out. Here is some pics:
#21 |
VA72C10
Super nice!!!
#22 |
![]() Join Date: Dec 2006
Wow motor looks great
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#23 |
Tot Roddin'
Beau-tiful!!!!
That motor looks amazing. ![]()
#24 |
I finally got the 700R4 transmission in and working great. I ended up changing my stock crossmember to the one from Early Classic. It gave me the room I needed to run the exhaust. I highly reccomed spending the 90 bucks if your looking at doing the 700 conversion. I put a large aftermarket cooler on it because of the heat from the stall converter. I adjusted the TV cable myself, and then took it to a transmission shop to double check my work. He drove the truck and said he wouldn't change a thing. It is the best thing I have done to the truck so far. The tranny made it very driver friendly. I also had the exhaust done. I ended up going with dual 2.5" 40 series flowmasters. I need to take some pics of the finished product because it turned out great. I ran the exhaust through the framerail and came out behind the rear tires. I will try and get some pics up soon. My header paint is burning off faster than I expected. Don't use the Eastwood spray can crap or you will be dissapointed. I followed the directions step by step. I love the Sanderson CC10 headers, but wish I would have spent the extra money to get the ceramic coated ones. I think I will have the ones I bought chromed eventually.
#25 |
Dan how about some pictures of the engine compartment? How did it turned out?
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Tags |
1970, black, c10, fleetside, swb |
