12-17-2010, 02:03 PM | #1 |
Gearing w/35s
Would 4.56 gears with an sm465 and an NP205 (all in a 1969 K20 with a 292) be too tall of gears (33-35" tires)?
*The truck will never be driven on the highway, only in off road situations and the occasional towing of a boat 40 miles on back roads. It might take one 200 mile trip to the outerbanks.
'69 K20 292 4spd 4x4 - project 27,000 orig. miles '98 1500 suburban 4x4 - driver 219000 orig. miles |
12-17-2010, 02:37 PM | #2 | |
Getcha Pull
Re: Gearing w/35s
Since first is 3.58 on the 465 compared to the 2.48 of the 400, and 2.52 of the 350 you can get away with a slightly smaller gear without overly negative effects. I'm building a truck with a 465, and 35" tires myself, and am going to be using 3.42 gears. Partly because it is what I have laying around... Also because I want to do more highway. I'm just going to get my extra reduction out of the T-Case when needed. Not ideal, but eh.
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
12-17-2010, 05:41 PM | #3 |
Re: Gearing w/35s
Roger that, I was going through your build thread and I gotta ask- How long did it take to wire wheel your frame?
12-17-2010, 06:26 PM | #4 |
Getcha Pull
Re: Gearing w/35s
Well, I only had to do about from the tranny crossmember back. In front of that had a nice oil/grease coating to keep it from rusting. Without the bed in the way though, I'd say it took me about a hour, maybe a hour and a half. Didn't really time it. The frame mainly had surface rust. Cleaned up easy.
12-17-2010, 10:30 PM | #5 |
Re: Gearing w/35s
I think you meant 2nd is 3.58 in the SM465? Although now that I think about it, the 80's trucks listed 1st as L and 2nd as 1st? Either way, the SM465 gives you plenty of gear with it's granny gear.
4.56 and 35's is a great choice for a truck that never sees the far side of 60.
12-18-2010, 02:10 AM | #6 | |
Getcha Pull
Re: Gearing w/35s
12-18-2010, 02:23 AM | #7 |
Re: Gearing w/35s
I have a 350/350/np205 combo and 3:73 gears, i went to 33's back around 93' and i'm pretty glad i didn't buy 35's, its a bit labored off the line, but low rpm's on the freeway. I often wanted to go to 4:11's but could mever come up with the justification on spending the coin.....yet
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-18-2010, 09:04 AM | #8 |
Re: Gearing w/35s
On that 4.56:1 truck,that came with 7.50-16s originally,by going to 35s you'll end up with right about 4.10:1 at the road/ground.It's a good ratio,especially with a 4spd.I like 4.10s with 35s because I'm on the road way more than 4 wheelin.With that you end up with right about 3.73s running 35s.I do fine off road with that.
