Old 12-20-2010, 02:50 PM   #1
k5hart
k5hart's Avatar
Child Seats - Opinions
Are any of you using child seats in your Blazer back seat? What's your thoughts on them? How do they seem to work?
I'm looking at mine and thinking man the kid sure is up high in the truck. Questioning the safety in something like a roll over. I know it probably won't happen but I'm just thinking the worst. Has me thinking about selling the truck for something else. Am I over thinking this??
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 12-20-2010, 02:54 PM   #2
matthew79
Re: Child Seats - Opinions
I don't think you're supposed to use any kind of a booster or child seat with lap belts.
matthew79 is offline   Reply With Quote
Old 12-20-2010, 03:03 PM   #3
k5hart
k5hart's Avatar
Both seats I've had give instructions for using lap belts. I actually use the lap belts in my ext. cab pickup and the wife's Equinox. A good point you bring up though. My pickup belts retract and lock. The blazer only slides through the buckle. Is there more chance for them coming loose?
Old 12-20-2010, 03:57 PM   #4
Burt4x4
Burt4x4's Avatar
I use a rattchet strap and strap down the seat to the floor right infront of the back seat and center...did that with all 3 of my kids and works great! Oh I have two large Eye-bolts mounted to the floor that the strap hooks too.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 12-20-2010, 04:30 PM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I did extensive research on child seats in the Blazer.
I used child seats for both my kids without any issue. Child seats are generally higher than the child's head which should add some protection in the event of a roll over. If you are concerned about a roll over, I would add a family cage to your truck.
I do not use booster seats. Booster seats are designed to position the child for the shoulder belt. With lap belt only seats, it is safer for the child to sit directly on the seat than use a booster. I confirmed this with the Washington State DOT and the WA State Patrol.
They do make safety seats that have 5pt harness for children up to the age of 8. All of them require modifications to vehicles belts and/or add mounting points.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-20-2010, 09:23 PM   #6
k5hart
k5hart's Avatar
Bouncy did you use the factory seat belts? Any issue with the tension coming loose?
I probably have a one in a million chance for rolling mine since it's two wheel drive and lowered but you never know with the crazy driving people out there. I will sell it before I put a cage in it or modify the floor some how. It's too nice of an original truck to do that.
Guess I'm more concerned about the seat belts holding the child seats in well.
Old 12-20-2010, 09:51 PM   #7
turp mcspray
turp mcspray's Avatar
My three kids were buckled in the back, with the factory belts. One of them since he was 6 weeks old. Never had any problems. I think if you roll one of these early blazers, you are going to be F%@$#& no matter where you sit!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 12-20-2010, 10:45 PM   #8
brandy hickman
brandy hickman's Avatar
I use the booster seat bottom part only. The lap belts are loose on the boys without the booster. I would rather have them on a booster instead of flying out of the seats
brandy hickman is offline   Reply With Quote
Old 12-20-2010, 10:53 PM   #9
bouncytruck
SKINNY TIRES RULE!
I've had no problem with the factory belts holding the car seats in tight. I would put my knee into the seat and tighten up the buckle as much as possible and it never loosened.
The only obsticle with the car seat we had was when it was tightened in, the buckle sat right behind the thin seat cover and you could feel it poking out. Neither kid ever complained.
bouncytruck 1972 K5
Old 12-21-2010, 09:59 AM   #10
k5hart
k5hart's Avatar
Thanks for the comments everyone. It makes me feel a little better. I guess I'm just going to have to try it and see. Also need to get my belts restored if I keep it.
Old 12-21-2010, 10:17 AM   #11
63chevyll
gets board easy.......
63chevyll's Avatar
Good info guys.
63chevyll is offline   Reply With Quote
Old 12-21-2010, 01:14 PM   #12
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here in Ontario you can have a child seat mounted anywhere in the vehicle.
If it's in the front seat there can't be a air bag (or ability to shut it off).
Where ever it's mounted it HAS to be tethered.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
