12-20-2010, 03:06 PM | #1 |
crewcab question?
What is the difference in a 3/4t and 1t single rear wheel crewcab? Is it just the springs? I know they use the same frame,rear axle and front brakes. Remember this is NOT a dually. Thanks
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
12-20-2010, 03:12 PM | #2 |
Arrived on a Pale Horse
Re: crewcab question?
I think something with the ball joints and spindles are different. I found this out shopping for drop spindles, I'll be watching the thread b/c I've been wondering the same thing.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
12-20-2010, 04:16 PM | #3 |
The frame is different, as well as the spring pad width and the front brakes.
1949 Five Window, 1973 Step Side, 2000 Z71 |
12-20-2010, 05:24 PM | #4 |
I could have sworn they use the same frame on the crewcab. They both use the full floater. Maybe the spring perches are different,wider on the 1t. and it's not 4wd.
12-20-2010, 04:36 PM | #5 |
What axles do they have? I thought the 3/4 ton had a Semi-Floating 14 bolt and the 1 ton had a Full Floating 14 bolt.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
12-20-2010, 05:18 PM | #6 |
If it's a 4x4 the front is a Dana 60 on the 1-ton and a Dana 44 on the 3/4 ton.
Paul Waddell Front Royal, VA 1986 K30 Crewcab, SRW |
12-20-2010, 09:36 PM | #7 |
I thought the spring hangers were mounted differently too, but its been a long time since I knew what I was talking about. Didnt something have the springs mounted under the framerails instead of beside them, with more inboard pads? IDK, my 82 crewcab&chassis (just made that up) has them outside the framerails just like my 97.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. |
12-20-2010, 09:42 PM | #8 |
Real Projects never die
i always heard they used the same frames on the crew cabs, never compared the 2 so other than that i cant help ya.
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
12-21-2010, 02:27 AM | #9 |
the only thing Ive found different on the SRW CREW CABS is the number of leafs in the rear spring pack and the spindles and the differance in the spendles is the way the caliper mounts and the way the brake line hooks to the caliper and most 3/4t didnt come with hydroboost brakes
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
12-21-2010, 03:45 AM | #10 |
Yes they both use a full float 14 bolt but the hangers and purches on the 1 ton are different. In the later years a semi float was a option but I have never seen one under a Crew. As pigrig said Hydro boost is an option and a must have IMO.
12-21-2010, 03:58 AM | #11 |
3/4 ton caliper
1 ton caliper
12-21-2010, 07:02 AM | #12 |
Next!
Frames should be the same
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
12-21-2010, 01:49 PM | #13 |
Yep, the frames are the same. Thanks!
