12-21-2010, 02:33 PM | #1 |
How much power are you making with your I6
Ok lets here what you got and what your making for power!! Pics! and what your using!!
I would start but mines stock and waiting to be put in.
58 Jeep willys pickup 67 K10 4x4- soon to be trail truck TROUBLE MAKER RACING "If you can't stand BEHIND our troops, please stand in FRONT of them." |
12-21-2010, 03:07 PM | #2 |
Grandpa in the rustmobile...
Re: How much power are you making with your I6
cool thread i'll bump it, I know a few people have some hopped up ones!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
12-21-2010, 03:08 PM | #3 |
stock 235
12-21-2010, 03:28 PM | #4 |
cant wait to get mine upgradddeedd and makin some power but i need to learn to save money better lol
12-21-2010, 03:37 PM | #5 |
Here's mine. Offy intake and holley 350 2 bbl. Langdon's headers and dual pipes out the back. Offy valve cover and an HEI. Stock 140 horses. Now it's gotta be twice that. At least. Ya right. Not likely. LOL!!!
12-21-2010, 04:19 PM | #6 |
ha those look awesome lol
12-21-2010, 04:22 PM | #7 |
Where's my beer?
Not much stock on this 250. Unfortunately, my uncle did the engine more than 10 years ago and doesn't remember exactly what he put in it. I know it's bored at least 30 over, a slightly bigger cam, clifford intake, Holley 390, ported head, header into dual exhausts, and HEI. I have no idea what HP it's making, but I sure would love to find someone who can really tune it right. It's never run as strong as I know it can, but it still runs strong enough.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
12-21-2010, 05:38 PM | #8 |
I have two and have no idea about either one!
Mark |
12-21-2010, 05:48 PM | #9 |
that is a really good before/after pic
12-21-2010, 07:03 PM | #10 |
I built a 292 to replace the 250 in my 68 GMC 1500. It has so much more torque than the stock engine that it broke both rubber motor mounts.
12-21-2010, 10:47 PM | #11 |
i dont want to hijack, but i think it would also be nice to see what everyone is doing with the spark plug wires, its kinda an odd thing but im kinda tired of mine being just hanging there and floppy. to me it really dresses up an engine if the plug wires arent floppy...
12-22-2010, 01:36 AM | #12 | |
12-22-2010, 01:55 PM | #13 | |
12-22-2010, 03:47 PM | #14 | |
I would look better mounted just below the plugs, with each wire just coming up out of the tube about 1 1/2-2 inches. I'm in the process of making a similar setup, but for a V8. I can get pics if you need them.
12-21-2010, 10:49 PM | #15 |
I saw a CLEAN I6 sparkplug wire routing awhile back..I wish I saved it for ya sixyeight
12-22-2010, 01:34 AM | #16 |
Here's mine.....it's a 250 L6. It has clifford intake and dual shorty headers. It has a 4 barrel eddelbrock carb with electric choke. I have a single flowmaster exhaust dual in single out. The PO had it bored .60 over and the crank has been turned .10. The books say it was 155 HP stock and I know it a bit faster than it was. I like it alot. It has 550 miles on the rebuild and seems to run better every day. Thanks for starting this thread
12-22-2010, 01:56 PM | #17 |
the boat guy
kyull67 claims to be making 300hp with his 250, and I believe him! The engine is torn down now waiting for a turbo.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
12-22-2010, 03:24 PM | #18 |
250 Never been rebuilt Runs like a TANK
12-22-2010, 03:53 PM | #19 |
Im interested in pix matt
12-22-2010, 03:59 PM | #20 |
x2 on the pics, please
12-22-2010, 04:58 PM | #21 |
Cruzin
heres the last pic of mine in the truck just stock but it ran like a top i beat the heck out of everyone i've owned, just before i tore the truck down i was doing burnouts one after another until the carb started flooding so i decided to tare the truck apart. You CAN'T beat and inline
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
12-22-2010, 06:34 PM | #22 |
Where's my beer?
Just some simple wire separators clean up the plug wires a lot.
12-23-2010, 09:43 AM | #23 |
OK here's the pics of what I'm working on. I started with 1" tubing, cut to length, then drilled the holes.(1st pic)
In the second pic, I had a buddy machine a set of plugs to cap the ends off. 3rd and 4th pics, plugs installed. Last pic is with an 8mm wire run through with a grommet. I drilled 9/16" holes because the NAPA grommets I used were made for a 9/16" hole with a 3/8" opening. I had to use a 3/8" opening because the wire has a tendency to drag and pull the grommet into the tubing. I will be sure to use some kind of lubricant to make the wires slide through the tubing and grommets easier. All I need to do now is have some mounting tabs made and welded on. They will be mounted through the valve cover mounting holes like most loom setups. The wires will simply just drop down out of the tube to the plug. I plan to do a full write up with photos when completed.
12-24-2010, 07:28 AM | #24 |
lovin' the lowcountry
I'm also looking for some ideas to get some HP out of my 250.... Hubscrub, it kinda looks like you ripped the heart out of that truck with the trail of oil out the front of it, haha.
Chris 29461 72 SWB stepside 71 SWB stepside DRIVE IT LIKE YOU STOLE IT! |
12-24-2010, 09:33 AM | #25 |
Cruzin
yea i just drug the trans out on the ground to the front man that thing was greasy the truck was unmolested since 71 and i think the trans was uncleaned since 71
