12-23-2010, 10:54 PM | #1 |
Help on vin and paint#
I have found sites that help with vin tag decoding but i can't find anything on bench seat color or exterior color. I also have custom trim and my tag says
trim-STD(standard). paint-RPO721H vin-OC144L1O7148 help please. Last edited by bad61; 12-23-2010 at 10:56 PM. |
12-23-2010, 11:04 PM | #2 |
CLASSIX Truck Club
Re: Help on vin and paint#
The exterior code should be on your Tag on the driver side kick panel. Not to sure about the seat color.
12-23-2010, 11:05 PM | #3 |
CLASSIX Truck Club
Sweet truck by the way. A lot of 61's popping up.
12-23-2010, 11:07 PM | #4 |
I found the tag I just don't know how to read it.
12-23-2010, 11:10 PM | #5 |
Resistance is Futile
Did you try the FAQ section above the threads? There is a vin thread; haven't read it though......
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
12-23-2010, 11:12 PM | #6 |
love these trucks
12-24-2010, 09:51 AM | #7 |
What's the story on the circle track style truck? That is one mean looking son of a gun!
Slowly but surely getting it done. |
12-24-2010, 09:56 AM | #8 |
x2....mean-a$$ rubber under those fenders.....looks like it should be slinging some dirt and mud.
12-24-2010, 10:29 AM | #9 |
1961 crewcab
paint-RPO721H.... in 1960 rpo721 was called pure white. solid color truck, not two tone.
vin-OC144L1O7148... 0= 1960, C= 2wd, 14= swb 115", 4= pickup, L= los angeles assy. plant, 107148= 7148th built that year.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
12-24-2010, 10:48 AM | #10 |
thanks missoula!
12-24-2010, 11:00 AM | #11 |
I like your work Jons custom shop! I was raised in billings and have deep roots in montane, thanks for your help. The trim says it's standard but it's custom, could they have screwed up at the plant?
12-24-2010, 06:34 PM | #12 |
1961 crewcab
I was thinking the trim-std might refer to the interior, the bbw and custom cab stuff might have been a rpo that would be on the build sheet, but not the tag.
I have a 66 bbw with the trim , and the build sheet lists both of them , I will have to check the kick panel tag and see what it says.
12-24-2010, 06:49 PM | #13 |
do you have the chrome trim that goes in the rear window rubber? i'm on the hunt for it.
12-25-2010, 01:43 AM | #14 |
1961 crewcab
as far as I know the very first pic you posted is correctly trimmed out.
in the aftermarket you can get a rear rubber with a chrome bead lock, but it is not factory correct.
