Help E Brake
Hello,
I need a picture of the emergency brake frame bracket (parking brake) on a Task Force truck. It has been so long since I removed that I do not remember how to put it back. I took the rivets off. I now need to relocate it a few inches back. I need to see the bracket and how the cable attaches to the lever on the frame bracket. Thank you, |
Re: Help E Brake
Hope these help some...
I don't have any up near the front of the cab. Bob |
Re: Help E Brake
stock location on my '59 1/2 ton.....a couple inches back from frame deformation for steering box......
Re: Help E Brake
Has anybody used a different type of brake pedal, such as one from a 70s car?
Re: Help E Brake
DransportGarage, hsdropout,
Thank you very much for the pictures. I have been looking on the web for days with negative results. I want to keep the E brake somewhat original. I have a Lokar universal kit but I really like the brakets and levers under the cab as well as the bracket on the frame. And most important the brake handle in the cab. Now I just need to get a hold of Control Cables and order a new set of cables. Next time I will take pictures before I take things apart. 72Mountaineer, I still have the OEM pedal but I will change to a flat shaft pedal to match the accelerator shaft. Again, thank you all for the pictures. |
Re: Help E Brake
Look at my build thread, I used a 74 truck inside foot pedal assemby and cable mated to the stock back linkage.
#7 | |
Re: Help E Brake
I got to do my can corners as well. I see you replaced the lower door hinge caged nut...IS that working out with just replacing the lower portion and not the whole hinge pocket? Thanks for the help. |
