Old 12-29-2010, 01:27 PM   #1
OrrieG
OrrieG's Avatar
Task Force Interior Cab Corner Fill Template
A member ask for a copy of the template I made so I figured I may as well just post it in a thread. Attached are two files one 11x17 and a second that is (2) letter size with registration marks.
My notes are not to legible but the only clarification is at the part behind the door jamb the plate needs to be bent up over the brace. It's obvious when you look at it. This template is for the drivers side, it flips for the other side. I found that my two sides were slightly different and your truck may be too. Critical to me was to get the outside tight to the metal so go a little large and trim to fit. The inside over laps the floor by about an inch for the plug welds.
I used 16 gauge metal, cut with a jig saw and fine tuned with a die grinder. On the corner side I spot welded it to the body, on the cab side I drilled holes and plug welded it to the floor. I then put a generioius bead of 3M Body Sealant around all the edges to seal it. I would not recommend a full weld at the exterior body line, you will warp the metal and push it out which will cause problems.
Here is a photo of it installed too.
Old 12-29-2010, 01:49 PM   #2
bensimmons_05
bensimmons_05's Avatar
Re: Task Force Interior Cab Corner Fill Template
I had already planned on doing this one, so this helps that much more! Why recreate a design flaw??!!
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 12-29-2010, 05:36 PM   #3
Kim57
Kim57's Avatar
Cool, thanks for posting OrrieG.
Kim
Kim57 is offline   Reply With Quote
Old 12-29-2010, 08:27 PM   #4
Rude Dude
Rude Dude's Avatar
Thank you for template much appreciated
Rude Dude is offline   Reply With Quote
Old 12-29-2010, 09:41 PM   #5
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Wow! It looks identical to mine! Nice work.
ChuckDriver is offline   Reply With Quote
Old 12-30-2010, 04:18 AM   #6
Woodbutcher
Woodbutcher's Avatar
Cool, thanks. I remembered the original post and was planning on doing your mod. This makes it much easier.
Gotta love a community like this.
If the women don't find you handsome, they should at least find you handy... Red Green
Keep your stick on the ice, Woodbutcher
Woodbutcher is offline   Reply With Quote
Old 12-30-2010, 01:45 PM   #7
OrrieG
OrrieG's Avatar
Great minds think alike! Or if we take long enough we stumble onto a solution to the challenge.
Old 12-30-2010, 09:14 PM   #8
ChuckDriver
I tend to stumble a lot!!!!!
Old 12-30-2010, 11:27 PM   #9
bensimmons_05
I , too, do this often.
Old 07-30-2012, 03:07 PM   #10
Maximus
Maximus's Avatar
thought i would revive a dead thread... does anyone know if the attachments are to scale? i am at work (away from my cab) and if dont get a response will just bring it home and test fit it, but i am near a friends machine shop and will drop the template off to him if they are already to scale
and regardless - Thanks Orrie!! i know its simple, but any time savings is appreciated in my book!!!
Maximus is offline   Reply With Quote
Old 08-01-2012, 12:34 PM   #11
OrrieG
OrrieG's Avatar
The ones I email are. Send an email to reddogeb@yahoo.com and I will get them to you.
Old 08-01-2012, 12:42 PM   #12
Maximus
Maximus's Avatar
Thanks Orrie, but I already printed the 11x17 one and made sure printer didnt change scale, and it was darn close so I will just use those - Thanks again! this saved me some time!
Old 08-01-2012, 11:33 PM   #13
OrrieG
OrrieG's Avatar
Glad it worked out for you.
Old 08-02-2012, 07:17 AM   #14
buggy5872
buggy5872's Avatar
What is this for? Extra strength or just to make it look better?
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 08-02-2012, 02:37 PM   #15
Amorget
It's for eliminating the inner cab corners which are very prone to trapping moisture (and other stuff, like gloves, hats, etc) and causing rust.
Amorget is offline   Reply With Quote
