Old 01-01-2011, 10:15 PM   #1
Boog
laying low
Boog's Avatar
OD trans and brake booster from a 97?
I have the 97 GMC my daughter recently wrecked and am wondering what to do with it. I have the 69 Chevy needing a power booster/master cylinder and a trans.
The 69 has a mild carb'd 350 and 4.10 gear. While it has a plain t350 trans in it when the gas prices go up I give more thought to the benefits of OD. It's a long way away from being ready to drive but I have these parts now so why not.
I can adapt the brake booster and since it bolts up close to the firewall I think I'd like that better anyway. It's less than a year old by the way.
The trans is something else to consider. Being a 97 it's a 4l60E? and electronically controlled? How would I go about adapting that and the speedo to the 69?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-02-2011, 12:38 AM   #2
hugger6933
Re: OD trans and brake booster from a 97?
I would think the booster would be fairly easy ,just get the pushrod length right. The trans however is another story . it requires a cotroller to make it shift and it will also have to have a TPS for part throttle downshifts. The whole drivetrainwould be nice in there with the fuel injection and would not need much more electronics than just a trans install to make work. There is a few copanies that make a stand alone harness for the 4l60e but they are pricey. The od idea is a good one and maybe a 700r4 or better yet a 200r4[same length as the th350]. Since your in the area maybe you could talk with Ron Q. @ Searcy auto salvage. He is a friend of mine and is a real car guy as well as a nice man to deal with. Jim
hugger6933 is offline   Reply With Quote
Old 01-02-2011, 07:37 AM   #3
Zeke
Active Member
Since you have the whole 97 wouldn't be easier to swap the heads, fuel injection and trans or even complete engine/trans combo? You already have the computer and harness and having the donor truck would really save $$ and gas running back and forth picking up parts you need but missed. Hard to beat fuel injection and OD trans for gas mileage.
I haven't done this but do remember seeing threads on tpi swaps.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 01-02-2011, 07:46 AM   #4
Zeke
Active Member
just saw your post on the 97, glad your daughter is ok.
1969 C10 350 3spd
Old 01-02-2011, 09:37 AM   #5
Boog
laying low
Boog's Avatar
Well I really wanted this truck to be "low tech" as in NO ecm, no injection, no sensors, etc. Just a basic truck. Yes I know all the benefits of late model fuel injection and engine management but I wanted to get back to a qjet and distributor and twist on it myself like the old days.
The truck currently has a 4.10 gear. That'll be fun but with high gas prices I want an alternative. I also have a 3.08 open rear end I can put in if necessary. I'm not going to spend a lot trying to use the OD. There is a controller and speedometer converter to think about.
Just kicking around the idea.
Boog
primer is finer
Old 01-02-2011, 01:25 PM   #6
68 TT
Still plays with trucks
68 TT's Avatar
You can get a carb intake for the Vortec engine so you gain the better heads, roller cam and serpentine accessories but still have the carburetor you desire.
You can run the 4L60E with a 91-93 vintage stand alone diesel trans controller or program an older PCM like the 16197427 from the 94 & 95 trucks to run the trans as well for very little cash.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-02-2011, 09:31 PM   #7
hugger6933
Hate to steal a thread but, 68TT could you give some more info on those controler options you mentioned? I have some of those 4l60e laying aroud. I also have some that are from the 4.3 type bellhousing as the ls seris would not work as easy because of the pump depth. Jim
Old 01-02-2011, 11:32 PM   #8
Boog
laying low
Boog's Avatar
Thanks TT but the thing is I already have the engine I want in the truck and it's freshly built. No vortec here. I am interested to here about standalone tranny controllers though.
Boog
primer is finer
