01-03-2011, 12:27 AM | #1 |
how about some 81-87 10" lift pics
i want to run a 10" lift on my crew short bed with 38 15.5 20 mtz that i bought for it but skyjacker says they will clear with a 8" lift and super lift says that i need a 10". im thinking 10" might be the way to go so i need some pics thanks. and what brand do you guys think rides better i have run skyjacker in the past and the springs saged on me after a few years so im to impressed with them.
01-03-2011, 12:36 AM | #2 |
gets board easy.......
Re: how about some 81-87 10" lift pics
I had 10 on my blazer and cleared 39.5's.1984
Posted via Mobile Device |
01-03-2011, 03:08 AM | #3 |
im sure a 10" will clear 38s and i think i could get away with a 8" its how wide my tires are there 15.5 wide with 20X10 wheels with a -25mm offset. i don't want to bash up my fenders or trim them the truck will see mostly street use and very rarely if at all see off road use.
01-03-2011, 11:02 AM | #4 |
heck I clear 38's with 5" of lift. I still need to do a little trimming though, only time it contacts is full lock and in a good bind.
38" TSL's Last edited by jkade; 01-03-2011 at 11:04 AM. |
01-03-2011, 11:22 AM | #5 |
Heres a mock up pic of my brothers truck. Its a 10" on 42s.
The guy he bought the wheels and tires from had them on a 78 with 8" lift. |
01-03-2011, 12:01 PM | #6 |
one of my old rock crawlers was a 84 k5 with a 8" and 35s on 15x10 wheels and i tore the hell out my fenders the first weekend at full flex its funny it was military green that pic brings back some memory's wish i still had it but after years of wheeling the the floor tore it self apart past repair or as much as i was going to do i still wish i would have done a body swap on it. i beat the hell out of it all weekend and still drive it home down the interstate at 80-85 miles an hour with no problems
01-12-2011, 01:07 PM | #7 |
i finlay dug up some pictures, therse are the only two i have
01-13-2011, 02:20 AM | #8 |
what size tire is that they look like 40" tire's
01-13-2011, 12:08 PM | #9 |
40's, on 20x10's
well technicaly, 39.5s |
01-14-2011, 02:43 PM | #10 |
I cleared 38x15.50's with a 6" lift, but had to barely trim the fenders on the back edge. Took less than an inch off the corner. An 8" lift would definitely clear them. After I put the Bushwacker Cut-out flares on it, I could probably get 38.5's under it without any more lift. Keep in mind, my truck cleared the tires easily height-wise, but the width got me. If you get a more narrow tire, like a 38x12.50, you could probably clear them with a 6" lift.
01-14-2011, 03:00 PM | #11 |
It also depends upon what your plans are to do with it.
If it's a mainly street driver and light trail/OR use you can probably get away with 8" but if you plan on getting in full compression or extension situations you are going to need more lift. I ran 40's on my 79 Jimmy with 6" Skyjacker and added a cut of overload rear spring piece to the spring packs with a Rancho taper shims to get another inch and then had a 3" body lift. Still had to do some minor trimming to the rear of the fron fenders.
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A Last edited by N2TRUX; 01-24-2011 at 11:38 PM. |
01-14-2011, 03:11 PM | #12 |
That's an awesome looking Jimmy. I was planning on adding a 3" body to mine for when I finally find somewhere to wheel around my home. My truck clears the tires enough for street driving, like you said, but if you're going to flex a lot, I agree with you.
01-15-2011, 01:19 AM | #13 |
i think im going to go with 10" just to be on the safe side i already bought the 38/15.5/20 mickey thompson atz's and i already have talked to alcan springs about building me a set of rear full 10" springs so i dont have any blocks.
01-15-2011, 01:16 PM | #14 |
2lo4me/ntlonuf/ntfstnf
heres my 84 crew with 8 inches of lift and 35x14.5's on it, im sure that your 38's would clear but i think that you would have to trim the fenders a touch so that you can turn the truck imo, i would go with the 10 to be safe.
62 GMC swb fleetside~ project: still undecided 84 Chevy 4wd crew cab 8 inch lift and 37" goodyear h1 pulloffs, still rockin the old mans former plate 2LO4ME 65 chevy 1 ton panel~ bagged/bodied duramax plans slowly in progress... 02 Silverado cclb duramax~ sas'd "bro" truck with more rust than imagineable... |
01-17-2011, 04:02 AM | #15 |
ya after looking at how your truck sits with 8" im going defintily gooing 10" thats a good looking truck.
01-17-2011, 04:48 PM | #16 |
I have a 9" on mine, clear 39.5 no problem.
01-18-2011, 02:56 AM | #17 |
very nice but you also have bushwackers to i dont want to cut up my fenders and bed side's. sick looking truck do you have more pics?
01-18-2011, 11:07 AM | #18 |
http://67-72chevytrucks.com/vboard/s...d.php?t=441105
build thread....there is more over at FSC.com if you wanna see em. btw this is my last truck......40" Ground Hawgs ....6" susp.lift with 3" body. Last edited by daytonagp4; 01-18-2011 at 11:18 AM. |
01-23-2011, 07:44 PM | #19 |
Heres mine, if you are still looking for pics. 84 k20 with 10 superlift front springs and shackle reversal a and 4'' rear springs with no block sittin on 38/15.50/18.
01-23-2011, 10:34 PM | #20 |
thats perfect that is the look im looking for thanks a ton i bought my 10" superlift front springs today i got killer deal on them there a year old and i got them for $250 i already ordered my rear full 10" springs from alcan springs they should be here in a couple of weeks or so. and i dont think anyone here gets sick of new pic's to look at so keep them coming!!!
01-23-2011, 11:47 PM | #21 |
More pics and info for the Brown and Tan truck!!
01-24-2011, 08:13 PM | #22 |
9 inches of lift on 38.5x16x16.5s
01-24-2011, 09:55 PM | #23 |
house of chevy's
my old truck 6" skyjaker suspension and 3" body lift cleared 38.5 with ease
1987 m1028 cucv d30 2001 chevy s10 2000 honda shadow sabre 1100 "it's going to be an interesting ride home" |
01-24-2011, 09:57 PM | #24 |
house of chevy's
heres another little bigger this time
1987 m1028 cucv d30 2001 chevy s10 2000 honda shadow sabre 1100 "it's going to be an interesting ride home" Last edited by 81ratrodc10; 01-24-2011 at 09:58 PM. |
01-24-2011, 11:34 PM | #25 |
Chris
that truck doesn't look like it has a body lift no gap between the bed and frame. It also doesn't look like 38's they look very small. it is freakin tall though.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
