01-05-2011, 03:11 PM | #1 |
1 Ton front crossmember in 1/2 ton??
OK I am gettin a lwb square on trade. Runs good, th350 needs a rebuild etc. Base model truck. I want to put 1 ton suspension under it. Is it as simple as unbolt a 1 ton crossmember and bolt it under the 1/2 ton? I know the 1/2 ton frames are thinner in gauge and shorter in height. How about the rear? Are the springs different lengths? I seen a thread about putting a 1 ton front end under a 1/2 ton not too long ago. I cant find it for hell now.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
01-05-2011, 06:48 PM | #2 |
Re: 1 Ton front crossmember in 1/2 ton??
give me a min
01-05-2011, 07:00 PM | #3 |
cant find it eighter
01-05-2011, 07:47 PM | #4 |
Crew Cut
the front will swap over no problem. dont know about the rear
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
01-05-2011, 07:52 PM | #5 |
Yes front susp. will bolt right up..you can even put the ton front susp..under a 67-72 frame..bolts right up to them..less 2 bolts..
I have a front ton susp out of a 2wd 87 crew cab dually here..$100..Only thing is the calipers are gone..rotors and everything else is there.. Last edited by 70BLAZERX2; 01-05-2011 at 07:52 PM. |
01-05-2011, 07:56 PM | #6 | |
01-05-2011, 08:01 PM | #7 |
I save everything....LOL
01-05-2011, 08:10 PM | #8 |
Me too. Wife hates my junk. I am not making it a dually tho. Just single rear wheel 1 ton stuff.
01-05-2011, 09:15 PM | #9 |
pics?
01-05-2011, 10:36 PM | #10 |
I havent gotten the truck home yet. Hopefully before the weekend and I will take pics then!
01-06-2011, 01:43 AM | #11 |
If you use a 3/4 ton 14bolt instead of a 1 ton 14 bolt then the rear axle should just bolt right up. I believe the one tons have the spring perches closer to the frame (I know the D70HD dually axle I have has the springs mounted closer to the frame, i know your not going dually, im just saying).
So really if you get the whole 1 ton front suspension and a 3/4 ton 14 bolt for the rear it should just bolt on!
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
01-06-2011, 06:03 AM | #12 |
hehe.
Im guessing it was my thread that was being referred to, my 1/2 ton frame was actually a 1/2 inch taller in the crossmember section than the 1 ton frame, so the brackets that set on the inside of the frame weren't usable, but hey I get to rip it all out again anyhow after discovering a bent frame. Hope your swap goes well spudz, post some pics too please, I haven't got to the rear of mine yet, but will have to when I put a new 1 ton frame under it. |
01-06-2011, 12:52 PM | #13 |
Ok here ya go, I had my buddy who is bringing me the truck tonight snap a pic. He has it loaded up and ready to go. I am going to ATEMPT to rebuild this transmission myself. Ive never been into a th350. BUT cant be any harder then 700/4l60s.
02-10-2011, 12:08 AM | #14 |
01-06-2011, 12:59 PM | #15 | |
02-10-2011, 12:12 AM | #16 |
www.73-87chevytrucks.com
Both front and rear will work if its a SRW. Remember Blazer/4x4 guys swap 1 tons all the time.
By inside brackets he means the ones the go from the frame to the crossmember. 1 tons have taller frame rails.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 02-10-2011 at 12:13 AM. |
