Old 01-05-2011, 07:55 PM   #1
chevyndn
8.1
im not sure if im in the right place for this, but has anyone messed with an 8.1 for a mid 2000's chevy pick up?
chevyndn is offline   Reply With Quote
Old 01-05-2011, 08:02 PM   #2
Critter
Future TOTM Winner
Critter's Avatar
Re: 8.1
Dirty Larry has one in his 78 truck. Technically they aren't an LS engine, but I don't think anyone is going to bash you for posting here. Here is the link to his swap pics.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-05-2011, 08:14 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 8.1
that would be a Vortec?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-05-2011, 08:36 PM   #4
chevyndn
Re: 8.1
ok, i wasnt sure what class it fell under. i found one and was thinking about buing it but i wasnt sure if anyone had done this swap or not.
Old 01-05-2011, 08:47 PM   #5
Critter
Future TOTM Winner
Critter's Avatar
Re: 8.1
I guess you could call them a Vortec Engine, but not an LSx. I'm no expert but I believe they are based off the old Big block engine same as a 7.4 liter 454, but the firing order is different. I'm assuming a lot of the wiring and computer adaptation would be similar to that of a 4.8/5.3/6.0 etc...but I'm just speculating. They make GOBS of torque and in my opinion are awesome for a swap. What were you thinking of putting it in?
Old 01-05-2011, 08:51 PM   #6
chevyndn
Re: 8.1
well i either want to put it in my 98 gmc or my 72 chevy pick... we have a 3500 flat bed pick up at my job and holy crap its a torque monster for a stock motor...
Old 01-05-2011, 11:37 PM   #7
68GMCCustom
Re: 8.1
if you need that torque for pulling....then it would probably be worth the horrific fuel economy.
Kurt -
Old 01-06-2011, 12:46 AM   #8
Critter
Future TOTM Winner
Critter's Avatar
Re: 8.1
Also the bad@ss-ness of having 496 fuel injected cubic inches would be worth the mileage.
Old 01-07-2011, 11:49 AM   #9
jdmathes074
Re: 8.1
.http://www.hotrodlane.cc/Streetstories/81%20swap.pdf
That may have some helpful information in it
jdmathes074 is offline   Reply With Quote
Old 01-14-2011, 07:15 PM   #10
Mr. 250r
Mr. 250r's Avatar
Re: 8.1
My friend has one and i got to drive it and yes it is a powerful motor but it only gets 9.5mpgs at the best which is really a buzzkill for it but if your not worried about mpg's and want some power its got that, also while towing a 20ft trailer with a 3/4 ton suburban on 39.5s and a big block got same gas mileage so thats always a plus
Mr. 250r is offline   Reply With Quote
Old 01-16-2011, 01:03 PM   #11
tonypaul
tonypaul's Avatar
Re: 8.1
I got a brand new 8.1l crate engine in my garage that I was going to use in my 68 GMC. I went with a different motor. I will sell it cheap if interested. I have a ecu and a dbw pedal for it but no harness.
tonypaul is offline   Reply With Quote
Old 01-21-2011, 06:55 PM   #12
tonypaul
tonypaul's Avatar
Re: 8.1
Attachment 682972
If anyone is interested in this motor I will let it go for $2000.00. Shop around all other new 8.1l engines are $5000.00 and up.....
Old 01-30-2011, 02:06 AM   #13
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: 8.1
Man, I dunno…..Helpful information as to what not to do maybe. I personally wouldn’t follow his complete recipe. While he did do an extremely clean install, he went to a lot more work than ever needed to be done. There is no reason to cut the frame to make room for the 8.1L specific exhaust manifolds as any big block (396, 402, 427 & 454) exhaust manifold or header will fit an 8.1L. There is also no need to cut the frame for the A/C compressor as there are alternate bracket options (medium duty truck and RV) for the 8.1L that puts the A/C compressor up high on the driver’s side nor do you need to make room for the EGR valve at the firewall when you can simply remove it all together and have the ECM tuner toggle off the EGR portion of the calibration. 8.1L engines after 2003 didn’t even have EGR valves from the factory. You also do not need to run electronic throttle unless you want to deal with a big hassle and spend more money on parts. If you must have cruise control, yes…electronic throttle will get you that much easier.
Lastly, you do not need to use a gimmicky Dakota Digital tachometer adapter when all you really need to do is set your existing tachometer to 4 cylinder mode providing you are using an aftermarket tach. If running an OEM tach….you may need this hokie thing. MSD sells one as well.
Now this one is a true hack job.
Tonypaul,
What is that 8.1L out of? Looks like a 2001-2003 medium duty truck or Workhorse RV engine by the location of the water inlet, existence of an EGR valve and black valve covers opposed to bare aluminum. Nothing wrong with that….all years of 8.1L are good. 2004 and are a bit better though in terms of electronics (upgraded sensors, coils, etc).
As for the fuel consumption comments, my 6.0L Silverado 2500HD drinks just as much as my 8.1L Silverado 2500HD under normal driving while the 6.0L drinks even more when loaded.
Here are a few pictures I took at work of the last of the production 8.1L’s. 8.1L production ended with the 2010 model year.
Smaller coils on 2004 - 2010 engines.
DirtyLarry is offline   Reply With Quote
Old 01-30-2011, 12:16 PM   #14
Critter
Future TOTM Winner
Critter's Avatar
Re: 8.1
That's a beautiful pic but a terribly sad story that goes along with it.
I used to work as a production engineer for an auto manufacturer that I disliked...lets just say it WASN'T GM. Even though I hated the brand it was still awesome to see all those drivetrains, body panels, and frames stacked up everywhere. If I could have been in a Chevy plant it would have been a dream come true, probably would have worked for free...or at least a little cheaper.
Old 01-31-2011, 12:53 AM   #15
Pop's C-10
Pop's C-10's Avatar
Re: 8.1
That is art...
Pop's C-10 is offline   Reply With Quote
Old 01-20-2011, 11:52 AM   #16
dan42
dan42's Avatar
Re: 8.1
That would be interesting in a little shortbed.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 01-20-2011, 12:34 PM   #17
Clyde65
Clyde65's Avatar
Re: 8.1
That would be fantastic in just about anything!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-20-2011, 06:35 PM   #18
chevyndn
Re: 8.1
hmmmm, if i had the space and money to come get it id be all over it!
Old 01-21-2011, 01:38 AM   #19
Zoomad75
K5Camper
Zoomad75's Avatar
Re: 8.1
The 8.1 really only shares basic architecture with the early big block. Heads DO NOT interchange and the deck height differs. You can't bolt a conventional 396-454 intake on one. This means you have to run the injection. I've got one came from a motorhome, but am trading it to DirtyLarry with some cash for the pcm and harness for my 5.3 swap.
Also, the head design could be considered similar to LS but on a larger scale due to the tall cathedral intake ports. Sharing with the LS/gen3 is the changed firing order.
8.1's are amazing engines in that I've driven many a motorhome over mountain passes in coaches from 20,000 to 26,000 pounds. They still get 6-8 mpg in a 24,000 pound coach. Then again in 3/4 ton trucks your lucky to get 14mpg. They are way underrated in that the same engine sold for Mercruiser for marine applications with a non-emissions type tune is pushing over 400hp with a proportional increase in torque. Larry's 78 with his 8.1 is an animal. Considering he's spinning heavy biasply Q78 swampers it will absolutely flat haul the mail and is a stump puller.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 01-21-2011, 01:38 AM   #20
Zoomad75
K5Camper
Zoomad75's Avatar
Re: 8.1
Double post....sorry.
Old 02-01-2011, 01:04 AM   #21
3r!c84
Badass
3r!c84's Avatar
Re: 8.1
This is what dreams are made of
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 02-01-2011, 01:33 AM   #22
chevyndn
Re: 8.1
amen to that!!!
Old 02-01-2011, 03:07 AM   #23
DirtyLarry
DirtyLarry's Avatar
Re: 8.1
Yeah, every time I go to the plant I wish I could walk around with a shopping cart and pretend I was at the automotive version of Home Depot. Each crate holds 3 engines. I would be happy to take home just one crate.
Old 03-13-2011, 05:58 PM   #24
1BadAction
1BadAction's Avatar
Re: 8.1
What kind of crossmember mods does it take to get a 8.1 into a 4x4 K5? lift necessary?
2010 Basalt Black Porsche Cayenne GTS - Daily driver
1991 2500 Suburban, Black - 454/80E tow monster, soon to go under the knife... Again.
1979 16' Action Marine/"Johnny Cash" Merc Bridgeport Champ Motor - Metalflake Maniac
1BadAction is offline   Reply With Quote
Old 03-15-2011, 05:43 PM   #25
1tonjimmy
1tonjimmy's Avatar
Re: 8.1
Nothing, the motor is basically a like an old BBC but with a taller deck height and cathedral port heads. Dirty Larry, if I am wrong correct me please. I was going to put an 8.1 in my Jimmy and it got destroyed. I did a lot of reach on stuffing the big ole motor in a 73 to 87 K5/Jimmy.
1tonjimmy is offline   Reply With Quote
