Old 01-06-2011, 07:35 PM   #1
67 chevy heaven
Trans ?????
I have the origional 2 speed powerglide transmission for my 67 C-10 truck. It has been totally rebuilt.
But.... I am not sure that it will be satisfactory in my truck behind a built small block 383 stroker. (for highway use)
I have been thinking of going with a TH 400 instead.
Will some of you guys that know about this give me your opinion. Any and all feedback will be greatly appreciated.
Shawn
67 chevy heaven is offline   Reply With Quote
Old 01-06-2011, 07:45 PM   #2
Valhalla
Valhalla's Avatar
Re: Trans ?????
Really it depends on horsepower and how the transmission was rebuilt.
If the motor is pushing 400+ hp then the tranny would need to have been built to handle that power. this is a lesson me and my buddies learned the hard way more than once in our younger years of supercharging and putting turbo kits on stock internal motors/trannys.
Stock th400 are beefy but the higher the torque and hp then higher the risk of failure.
My build thread for Project TiC TaC/Jazzmin Oh Yeahhh
Cheap work is never good and good work is never cheap. Lesson = learn to do it all the right way on your own.
SqueegeeMan
Valhalla is offline   Reply With Quote
Old 01-06-2011, 07:52 PM   #3
67 chevy heaven
Re: Trans ?????
I forgot to mention that the engine in pushing well over 400 hp!
What trans would be best. The powerglide was only rebuilt stock.
If a use a TH 400 I will have it built a little heaver to take the stress. More opinions PLEASE
Old 01-06-2011, 08:19 PM   #4
dave2953
Dave's not here, man
dave2953's Avatar
Re: Trans ?????
What gears are you running? I had a Powerglide and it was a great transmission, but wasn't practical because with 3.73 gears I was turning 3K @ 60 mph. I am in the process of switching to a 700R4, but I've heard that unless they are built they can crap out when exposed to high horsepower. Not sure if the TH400 is susceptible to the same problems, though.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 01-09-2011, 12:09 AM   #5
Fitz
Re: Trans ?????
Both the powerglide and the turbo 400 will take significantly more HP and torque than the 700R4. Johnny Winter built my turbo 400 for 1000 HP and it's lived for three years in my 67 stepside.
Check here:http://www.racewithjw.com/
Fitz is offline   Reply With Quote
Old 01-06-2011, 08:42 PM   #6
67 chevy heaven
Re: Trans ?????
I am running 3.73 gears in the rear.
Old 01-06-2011, 08:47 PM   #7
dave2953
dave2953's Avatar
Re: Trans ?????
If you stayed with the PG you'd be turning pretty high rpm's on the highway and fuel mileage wouldn't exactly be stellar. I would think a TH400 would be the way to go, but I'm far from a transmission expert. Of course the downside to going with anything other than a PG is that you'd have to spend the money to go that particular route. What is a built TH400 going for these days?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 01-06-2011, 09:59 PM   #8
66skylarkpost
66skylarkpost's Avatar
Re: Trans ?????
i'd pull the powerglide and save or sell it . i've built a handful for circle track use in 3200 pound street stocks and a stock rebuild wont handle 400 horses in a heavier package . theres a number of key components to upgrade ( input shaft, hubs, drums and good clutches ) and can be costly for a converter . being its the same length and uses the same yoke spline on the driveshaft as a 350 turbo with a 6" tail (short),a mildly built 350 would be fine for less money
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 01-07-2011, 01:01 AM   #9
geezer#99
geezer#99's Avatar
Re: Trans ?????
Powerglide and 400 turbo both have a final drive of 1 to 1. Rpm at 60 is the same.
Powerglides are one of the toughest trannies built. They were available behind 425 horse 409's in the sixties. They'll take a lot of abuse. I know. Every weekend. 60 mph down the highway. Into reverse. Tires smokin trying to go backwards. Finally stopped. Back we go for 100 feet. Slam her into drive. More smoke. Stop. Back to 60 again. Did this at least 3 times a weekend. That tranny outlived the car.
Makes me tear up thinkin bout the old days. LOL!!!
I'd use the glide especially with the 3.73's.
Old 01-07-2011, 03:51 AM   #10
rn2fine
rn2fine's Avatar
Re: Trans ?????
I agree with Geezer#99. Final drive ratio of 1 to 1 is same as TH400. Rebuild the Powerglide and have a shop use parts that will handle the HP. Should not be a problem since Powerglides are racers most favored auto transmissions. And you keep all else exactly the same like linkage, driveshaft, crossmember, etc...
72 C10 Burb 350 700R4
70 C20 LWB 350 Crate TH400
68 Chevelle
rn2fine is offline   Reply With Quote
Old 01-09-2011, 01:15 AM   #11
Maxxd07
Maxxd07's Avatar
Re: Trans ?????
With enough green stuff ALMOST any tranny can be made to take high HP.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 01-11-2011, 05:01 PM   #12
Fitz
Re: Trans ?????
Not a 700R4!
Old 01-11-2011, 06:40 PM   #13
hugger6933
Re: Trans ?????
The pg is great but with the heavy truck you would be better off withthe 400. I used to run pg's in my drag car [as did everyone else i knew] lasted forever launched off the brake alot at 4400 rpm car was 3860 with me and went 1.32 60ft times. Should have had a lower geared 400 to get it moving but it was leaving so hard could'nt stand much more[ she would stand almost chest high every pass] some times I miss that car. Jim
hugger6933 is offline   Reply With Quote
Old 01-11-2011, 09:12 PM   #14
406 Q-ship
406 Q-ship's Avatar
Re: Trans ?????
A 700 R4 can be used behind 500 hp as long it is in a very light weight vehicle. In a truck with over 400 hp......then no on the 700 R4. I would use a TH400 over the glide for the gear multiplication of 3 forward speeds. I have been looking at GMPPs 4L85E (an electronic TH400 with a .75 OD) as alternative for an heavy duty 4 speed auto trans. You can hang a Gear Vendors on the rear of a TH400 for that extra gear too. A overdrive is a must on a highway hauler with 3.73 unless you enjoy stopping at every gas station.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 01-11-2011, 10:47 PM   #15
Maxxd07
Maxxd07's Avatar
Re: Trans ?????
If built and setup right a 700 can be a fine tranny. I have one I built in my 80 4wd with a decent 327 (300+hp) and have beat the living crap out of and is still alive after 7 years of abuse. Some people have better luck than others but like 406 Q-ship said for the big hp and abuse the sure thing will be to use a 350, 400, or 4l80e.
Couple 80s
Couple 70s
One 68
Old 01-11-2011, 11:15 PM   #16
67 chevy heaven
Re: Trans ?????
Thanks so much guys for all info, ideas,and thoughts.
I think I am going to keep the glide. I have decided to incorporate a few things that you guys suggested.
I have contacted a guy that runs a trans shop who has performed work for me and some of my friends in the past. I am going to put the money in my trans and get something that I will be happy with. I am not too concerned with fuel consumption because I am not building it to use as a vehicle that I take on long trips.
You all are great! Thanks for everything.
Wish me luck!!!
Shawn.
Old 01-24-2011, 11:03 PM   #17
CEE1NG_RED
Re: Trans ?????
...is running a 2 spd powerglide transmission with a 4:11 gears practical for a daily driver? I believe the engine is either a 327 or 350.. I have a friend that wants to buy a 68 w/ a 2 spd powerglide trans with 4:11 gears. The engine is questionable...either its a 327 or 350. Either or, is this a good combination? Pros/cons please?
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 01-24-2011, 11:13 PM   #18
packers05
Re: Trans ?????
A 2004R is a direct boltin and can easily handle your engine with cheap upgrades
packers05 is offline   Reply With Quote
Old 01-25-2011, 05:45 PM   #19
gr8fun
Re: Trans ?????
Your stroker is mild at 400HP, and a 700R4 will take it fine on these trucks. I had a performance-built 700R4 behind a 519 HP 383 and I put 40K miles on it before I sold that project. My new-to-me 67 C-10 has a real mild 383 in it (I may liven it up with better heads, cam, and intake in the future) and I'm thinking hard on a 700R4 to replace the TH400 for cruising. A GV-unit is just no an option for me because for the price of one to bolt to the 400, I can have and extreme duty 700R4 and all the extras needed to install it, including a modified driveshaft.
gr8fun is offline   Reply With Quote
