a.c & stock heater firewall the same?
Will a ac heater unit fit in the firewall that had a stock non ac unit and vice versa on a 78 truck.It looks like the ac unit is larger on the firewall.I,m talking about the fan and box unit that bolts on the firewall in the engine compartment
Re: a.c & stock heater firewall the same?
I found a pic and the ac unit looks quite large,is there a plate to change from the ac unit to a non ac unit ?
The hole for the a/c trucks is different than the standard units but it is not hard to modify either way as the firewall is flat in that area.
the hole is in a different spot and is in a different shape, i put ac off a 79 on a 78, and the 78 did not have a/c previously.
i made a template off the a/c cab. layed it on the other cab, cut the whole bigger and filled in the rest, drilled some holes and mounted up the box 79 firewall ![]() 79 firewall with template ![]() 78 firewall after modification: ![]() all painted ![]() the box ![]() |
#5 | |
I like the note on your template... ![]()
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Ok thanks,it just that a friend has a truck up north but he doesn,t want the ac [no use up there]and he will trade me for mine[and i need air down here in the summer]We were just wondering how they would inter change but it looks I have to do some cutting and he has to make a plate
