01-06-2011, 09:22 PM | #1 |
1967 C-10 SWB LS-6 T-56
Body side trim
On 67-68 Nos body trim, what is the best way to polish it, with pulling off in this case, the black accent paint
Thanks |
01-07-2011, 12:53 AM | #2 |
Re: Body side trim
well i would say a nice steel wool would sand off the black and clean it up
01-07-2011, 06:08 AM | #3 |
Re: Body side trim
Actually, I want to maintain the factory black paint, so I was thinking something like mothers billet polish, would that work?
01-07-2011, 09:51 PM | #4 |
Grandpa in the rustmobile...
Re: Body side trim
Free bump im going to do this also, best way to get thru the crap down to good metal and what polish to use..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-08-2011, 12:28 AM | #5 |
Tot Roddin'
Re: Body side trim
bttt...
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-09-2011, 01:00 AM | #6 |
Re: Body side trim
You can clean them, but the dullness that sets in is the anodizing.
Those moldings are aluminum and have a coating, like anodizing. They are also surprisingly easily repairable of little dents and scratches too.. I restored a "big 10" that was about a 76 with the panel moldings that had a mustard colored insert paint color. You can metal work the dents out and sand smooth then buff to a mirror shine, actually much more shiny than stock. I used a nice big balfor buffer, but a bench grinder with 6inch buffs would work, too. (ust slower) same buff wheels as you would use for stainless. Ive heard of people stripping the clear coating with paint stripper, but with the sewn buff and brown compound you can burn it right off in the buffing process. you will have to tape and repaint the center color. I used black going back by the owner request.... Now.. doing it this way- if you dont reclear it, the polished aluminum will fade. I used the same catalized clear (ditzler polyurethane back then) It looked great, like chrome! The guy who owned the truck decided he didnt like it so shiney, so we dulled it down with grey scuff pad and he was satisfied... funny thing is, he had a midnight blue TA that I painted for him later and we buffed all of the windshield, rear window and belt trim (normally painted black) the same way and kept it bright.. he loved it. Short story, you CAN make it look like new with alot of elbow grease.. you could even strip and buff it by hand, but that would be a big job and alot o' rubbin without a buffer. (you could use a buff on a hand held drill, too) Good luck man! Edit... you know I remember I saw a product looking in a BMW catalog for my son's car... a product to brighten the anodizing.... it might be something to chek into... http://www.bavauto.com/shop.asp check for auto exterior trim cleaning and care. this stuff requires sanding with 2000 grit and a flow on sealer/coating. Looks promising if yours aint to bad.. is is 60.00 skins.. heres what it says: Restore oxidized aluminum trim. Simply wet sand using included remover and 2000 grit paper, then use the flow-on applicator to apply the water-based coating. Oxidized look disappears, leaving a shiny, anodized aluminum finish. Comes with instructional video Last edited by primrrd; 01-09-2011 at 01:12 AM. |
01-09-2011, 07:43 AM | #7 |
Re: Body side trim
thanks, that was very helpful!!
01-09-2011, 04:14 PM | #8 |
Tot Roddin'
Re: Body side trim
Great post primrred!
11-18-2012, 11:10 AM | #9 |
Re: Body side trim
I use aluminum foil , was kinda tarnished like having a yellow tint but shined right up after applying aluminium foil
