Old 01-07-2011, 05:54 PM   #1
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Question Which engine to look for?
Looking for one of the LSx engine family that support the V-8 to V-4 cylinder cut out function.
So my question is what year and model vehicle would these engines orginally come equiped with? Hoping these would be the 6.0 liter engines for performance for my heavy 4x4 and then on the highway be able to go into economy mode for fuel saving mode.
Thanks for your help in this matter.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 01-08-2011, 06:33 AM   #2
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Re: Which engine to look for?
I believe it came on the 2007+ new bod style trucks. It's Active Fuel Management (AFM) but I'm not sure how or if it would work well in a swap into an old truck because I'm guessing the trucks BCM might control the system but I'm really not sure.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-08-2011, 08:11 AM   #3
C20-67_N_MO
At least that's a start.
Not sure what the BCM is suppose to be but pretty sure that any function can be programmed in or out that is not needed. But still have the system work as intended.
Looking at long term project so planning now.
Thanks.
Old 01-09-2011, 12:35 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Keeping the AFM with a engine swap has been done on the board....just can't find them at the moment. Heres a link to another place that will have delt with AFM in swaps. Just might need to search for a bit because most seem to eliminate it.
http://www.ls1tech.com/forums/conversions-hybrids-28/
Oh and BCM= Body Control Module
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-09-2011, 03:06 PM   #5
C20-67_N_MO
Cool Thank you.
Will have to become a member there and check things out.
Old 01-09-2011, 03:51 PM   #6
dan76
I had an 08 Sub with the displacement on demand system and found the slightest grade, use of the A/C or engaging 4WD would instantly disengage the system. As a result I did not see a fuel economy increase attributed to it's use. It sounds great in theory but I didn't experience a benefit. Perhaps during periods of extended idling it would improve fuel mileage.
dan76 is offline   Reply With Quote
