01-10-2011, 09:06 PM | #1 |
Gas filler option when moving tank to rear of truck
For those of you that have forgone saddle tanks and instead installed a suburban tank between the frame rails what have you done for a filler? I really don't want to have the filler come up through the floor so I was thinking of installing one of these doors on the outside of the body and building the filler neck to go behind it. The door would be located behind the dually fender on the drivers side.
I am open to other options? Posted via Mobile Device
-------------------------------------------------------- 1984 CC Dually - 454 - TH400 - Western Hauler Edition Big plans are coming! My build thread HERE |
01-10-2011, 09:23 PM | #2 |
78 Big10 454
Re: Gas filler option when moving tank to rear of truck
The kit I got from Transfer Flow allowed the use of the original fill pipe on the passenger side of my square. It's still a long process and a pain in the neck to put gas in my truck.
01-10-2011, 10:36 PM | #3 | |
01-10-2011, 09:49 PM | #4 |
I posted a thread about this in the blazer/suburban forum, with not much luck yet. What I had in mind was cutting out the stock fuel door from another square body and having it welded in place in the rear, and then plumb the filler tube right up to the fuel door. I am still open for ideas too because my idea does involve a decent amount of bodywork.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
01-10-2011, 10:37 PM | #5 | |
01-10-2011, 10:42 PM | #6 |
I understand not wanting to go through the bodywork. I have also seen people route the filler up behind the tail light, so that the whole light assembly opens on a hinge to access the filler, but I havent found any results of how well they worked or how the wiring worked out...
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB Last edited by BigRed76; 01-10-2011 at 10:42 PM. |
01-10-2011, 11:37 PM | #7 |
In the Forgotten far North.
Put it behind the taillight
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
01-11-2011, 02:02 AM | #8 |
Home Built '87
Good example, what about boxing it into the inside of the bed behind a wheel well? Is there clearance for the filler tube between the box and the top of the tank?
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 Last edited by Gordonr1973; 01-11-2011 at 02:02 AM. |
01-11-2011, 07:39 PM | #9 |
I thought of actually cutting out the Suburban filler and placing it on my truck in the same place? Just forward of the tail light. I haven't researched this at all, but I have a Suburban and a truck, so I have everything I need.....ecept a welder and welding skills!
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD |
01-11-2011, 07:48 PM | #10 |
A rear mounted tank was offered in the 75-81 pickups and is filled from the rear at the plate. LMC carries the tank, sending unit, and the straps.
1949 Five Window, 1973 Step Side, 2000 Z71 |
01-11-2011, 09:41 PM | #11 | |
Not the license plate I'm guessing? It is lower than the top of the gas tank. Also can you tell me where you got the info? To my knowledge, there were no rear tanks in any of the square pickup trucks (from the factory) just blazers and burbs. Posted via Mobile Device
CHEVY ONLY Last edited by joe231; 01-11-2011 at 10:10 PM. |
01-11-2011, 10:06 PM | #12 | |
01-11-2011, 10:39 PM | #13 | |
yeller
That could be a retrofit kit they are offering.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 01-11-2011 at 10:40 PM. |
01-11-2011, 08:53 PM | #15 |
Took the drivers side tail light out and I think behind the tail light is going to work pretty easily. I will need to make a custom filler tube and fabricate a hinge for the light assembly but the initial look is this shouldn't be to bad!
01-13-2011, 06:38 PM | #16 | |
01-13-2011, 07:28 PM | #17 |
When you figure out the hinged tail light, make 2 so I can get one!
01-12-2011, 02:10 PM | #18 |
BTT... I'd like to know more about this rare rear tank option...
01-12-2011, 02:16 PM | #19 |
I'd place it behind the licence plate like a caprice. Just adapt the part into the existing bumper.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
01-13-2011, 06:35 PM | #20 | |
01-13-2011, 07:25 PM | #21 |
Right on the money 502ss,
I almost have my tail light filler worked out, just need to build a hinge (I'm a procrastinator ) Posted via Mobile Device
CHEVY ONLY |
01-13-2011, 08:41 PM | #22 | |
Oh btw..... Let's see some pics of what you have done! Posted via Mobile Device
01-13-2011, 07:56 PM | #23 |
I got it figured out in my head, just need to make it reality Posted via Mobile Device
CHEVY ONLY |
01-13-2011, 08:05 PM | #24 |
There was a rear mount location for the cab & chassis models (aka pickups with no box). I wonder if that's what LMC is showing.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-19-2013, 09:01 PM | #25 |
I love this thread!im putting a blazer tank in a 87 swb with blazer brackets and have been worried about the filler as well
Chris Heinz |
