swapping a 700r4 to 4l80e
maybe im not searching right but i couldnt find much info on swapping a 700r4 to a 4l80e. i found a great deal on a drivetrain combo via craigslist 383 with edelbrock multi fuel injection and serpentine setup. 4l80e and np241. will i need to lengthen or shorten driveshafts? and crossmember location will it stay the same? will anything change with the transfer case ive read there about the same. anything else will be a great help thanks. oh heres the link of what im gauging interest in.http://anchorage.craigslist.org/pts/2099452440.html
Gentleman Jim owner x2
![]() Join Date: Oct 2010
Re: swapping a 700r4 to 4l80e
It's pretty much the exact same thing, only the 4l80e is electronically controlled instead of by a TVS cable. None of the lengths will be any different. As far as changing transfer cases... from what will you be changing? The NP241 out of a 91 truck is going to be a driver's side drop. You can find them in passenger side drops, but it's hard.
1975 GMC Gentleman Jim #1 -357 / 700r4 1975 GMC Gentleman Jim #2 -350 / TH350 Last edited by lindstromjd; 01-12-2011 at 12:05 AM. Reason: Didn't pay attention to what I was reading. 4l80e and not 4l60e. Whoops... Those ones do have a difference. |
The 4l80e is longer than the 700r4. The 4l60e shares the same dimensions as a 700r4 in the earlier units. heres a chart with tranny dimensions. http://www.tciauto.com/Products/TechInfo/trans_dims.asp
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
luckily i have a driverside loop crossmember in my garage i mistaked for the correct one for my truck. talked to him he'll include crossmember driveshafts and exhaust anything i need hes scrapping the truck
I assume the Edelbrock computer will run the 4L80E? Otherwise, you're gonna need something to control it...
Slots go on anything!
If it is running and driving already, it should be controlling the trans anyhow. 1991 was the first year for the 4L80E in the heavier trucks, so the Edelbrock system either used the stock ECM or piggybacks it somehow. The ad says it includes the harness and everything, so you should be good. Try to grab the cluster, too. It is teh electronic one, to save a ton of hassles.
1974 Jimmy- 5.3/4L80e/NP241 |
i will he said anything extra i need for the swap since hes scrapping the truck. i doubt fuel tank will work so ill need later model tanks and fuel sending units than ill just use the pump hes giving me. im waiting for a vid of the engine running right now hes about 300 or so miles away from me so i wanna make sure it at least sounds like its running decent
I can't view CL ads here from work so I can't see the details, but I assume this is in a Crew or Burb square body?
I remember looking at a '91 crew 2wd diesel a few years ago that had an OD tranny. I was told by someone here (ElGracho?) that it was like a one year only thing and was a desirable tranny as it was not electronicly controled. It was not a 4l80e, but a 4l80; the "e" for electronic. Not sure if that was only in the square body applications, or all GM trucks that year though?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 01-11-2011 at 02:11 PM. |
The Edelbrock MFI coversion for TBI motors uses the factory computer.
There is no such thing as a 4L80 only 4L80Es. If there was they whould be very sought after. |
#10 | |
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
As far as the 4L80 non electric, you can, however do a valve body to make one from a 4L80E, or alternatively, start with a 4L60 and upgrade some parts. Shouldn't be hard to find a kit.
"Did you seriously just ask me what I need more power for?" ![]() "You're stupid, cause I've smoked plastic." ![]() |
