01-11-2011, 04:23 PM | #1 |
1972 C10 Brakes
Hey Guys,
Replacing the steel lines on the rear axle along with all the drum brake components The fittings that go to the wheel cylinders are 3/8 but the fitting that connects to the junction of the new brake hose from the frame is not but appears to be 7/16 Is this correct or just a typical issue with all these Chinese replacement parts from NAPA? Thanks. |
01-11-2011, 05:28 PM | #2 |
Re: 1972 C10 Brakes
i need to do this as well so any help you guys girls give will help two people
01-11-2011, 08:33 PM | #3 |
Re: 1972 C10 Brakes
I have run into this before and I installed fittings that reduced them down to the right size. Most parts places will have the brake line reducers.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
01-12-2011, 12:22 AM | #4 |
Re: 1972 C10 Brakes
You can order replacement lines from Rightstuff detailing or LMC truck.
