56 - autocross
Welding grade 8 nuts
I want to weld nuts into my frame before I finish boxing up the frame. If I weld a nut to the frame will it change the strength of the nut? How is this usually done?
![]() Join Date: Apr 2008
Re: Welding grade 8 nuts
Yes it will change the strength of the nut. It will anneal the temper, where it ends up depends on your welds Generally when you weld a nut on the inside of something it only needs to be tacked to hold it in place while there is no bolt in it. It should maintain a fair amount of strength with small tacks. If you weld all the way around then you might as well just get a gr 2 or 5.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
Im about to do the same thing, Im going to use lower grade nuts that arent heat treated because I know for a fact grade 8's are heat treated, thus welding will change the metalurgy and probably make them brittle(how much I dont know) Maybe someone else can chime in with more info on this.
I amount they loose is completely dependent on the amount of time they are exposed to the arc so there is no diffinative answer. I the question is does the item really require grade 8 strength? If not don't worry about it. You could always bump up the grip size of the bolt to compensate for the loss of hardness, say go 1/2 or 7/16 instead of 3/8. I'm also a big fan of these. They have a weldable flange. http://www.mcmaster.com/?orderview=n...d-nuts/=ajyb2h
1958 Fleetside shortbox 1965 Malibu SS 1970 Camaro RS 1972 Malibu wagon Last edited by Tchia65; 01-12-2011 at 03:33 AM. Reason: wrong link |
#5 | |
Old Heap Driver
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
How about using caged nuts.
I was thinking of these. Please forgive the referance to the other brand of truck!
http://www.classictrucks.com/tech/09...ig_welded.html |
#8 | |
1958 Fleetside shortbox 1965 Malibu SS 1970 Camaro RS 1972 Malibu wagon |
