sm465 to Nv4500
Does the floor need to be cut to make room for the transmission and transfer case shifters with an nv4500 swap. It is a pre 1995 nv4500.
The truck is an 86 1 ton with a 350SBC, sm465, and a np205 |
Re: sm465 to Nv4500
The NV4500 will fit under the floor just fine. the only thing you will have to cut is a new hole for your transmission shifter because the shifter on the nv4500 is about 4 to 5 inches farther back. Most people just get a floor hump from an automatic truck and cut the new hole. Im not exactly sure if the location of the t-case shifter changes.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB Last edited by BigRed76; 01-13-2011 at 11:26 PM. |
Re: sm465 to Nv4500
This might help http://67-72chevytrucks.com/vboard/s...d.php?t=431033
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
![]() Join Date: Dec 2010
Re: sm465 to Nv4500
Not the best pic I'm afraid, but maybe you can make out how the NV4500 sits in the floor of my truck. It's an original SM465 truck.
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
![]() Join Date: Jan 2008
Re: sm465 to Nv4500
I had a truck with a n4500 with a 205 transfercase. when I got the truck they had a piece of mud flap and towel wraped around the 2 shifters. The trans shifter and the 205 shifter were almost side by side, infact the hole for the trans and transfercase were not divided. I used a shifter boot out of a 95 chevy truck with a nv4500 and the stock 205 shifter boot. I had to do a little fabing and conect the 2 boots together at the mounting rings, its been a long while back can't seem to remember why I didn't weld a strip between the 2 shifter holes. I didn't cut the hole for the nv 4500 so I don't know if a strip of floorboard between the two shifters could have been saved. The transfercase shifter location remained in the same location as stock.
