BMW & ASE Master Certified
Quick Axle question
gotta question about axles... I've got a 10 bolt now, not original becuase I swaped it about a year ago... It had a better gear ratio of 3.42. I bought the axle housing only because the bone yard charges for the axle too. Got home, removed the cover and started to slide the original axles in and they didnt fit right, the spider gears were different size. Kinda like the hole was to big. Does that mean it was a 30 spline truck diff? I installed the original spider gears into that carrier and have been golden ever since. I ask so I dont have to remove the diff cover and brakes to count the splines. I am going to order a set of axles hopefully tomarrow if I dont have to pull the cover and brakes off. That away I can install the C5 corvette brakes. Thanks
clint So do I have 28 spline axles?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Re: Quick Axle question
Sounds like it....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
