01-14-2011, 07:58 PM | #1 |
Installing a new head, need 230 cu in torque values
I'll be replacing the head on my truck in a couple of days with another I'm having re-done. Does anyone have the torque specs for a 230 head? Any "hot tips"? It's pretty straight forward but I'm sure someone has some old secret they want to share.
Martin Gibson
USAF Retired 1964(-ish) C10 |
01-14-2011, 08:20 PM | #2 |
Re: Installing a new head, need 230 cu in torque values
Very important:
Make sure water pump is installed to reinforce the block. Front 2 near water pump only go 85 ft/lb, to not crack the water pump holes, the rest of the head bolts torque to 95. Torque in sequence, in 4 stages, gradually working up to final spec. Use thread sealant like ARP thread sealant. Use lube under bolt shoulder and washers. Sequence: Front-> 14. 10. 6. 2. 3. 7. 11 13. 9. 5. 1. 4. 8. 12 Good luck. Posted via Mobile Device Posted via Mobile Device
292 + TKO500 |
01-14-2011, 11:34 PM | #3 |
lkk
1966 GMC Current project 1966 Chevy C10 Sold 1985 C10 Sold 1968 El camino Sold 1954 Ford Anglia Sold 1973 GMC Suburban Sold 1974 Chevy C10 Sold Last edited by agent orange; 01-14-2011 at 11:36 PM. Reason: wrote in a wrong topic |
01-14-2011, 11:50 PM | #4 |
Thank you very much!
Martin Gibson
01-15-2011, 06:07 PM | #5 |
So I've been reading up on the head gasket install and I'm understanding to use no (none, zero, zip, nada) gasket sealer what-so-ever, just what is mentioned above on the bolt threads.
I'm very mechanically inclined, I've just never changed a head gasket on a big engine before. I don't feel "challeneged" at all, just need to verify good info and technical info as well as welcome any tips from the folks that have alot of experience doing it.
Martin Gibson
USAF Retired 1964(-ish) C10 Last edited by Martin64; 01-15-2011 at 07:15 PM. |
01-16-2011, 01:02 PM | #6 | |
292 + TKO500 |
