Old 01-16-2011, 02:31 AM   #1
t korinek
Truckin' Krazy
t korinek's Avatar
Tilt column
RV Tilt
Tilt is tight
no damage or pry marks on the tilt head
Shifter handle spring is missing
Turn signal switch arm bent, another non cruise arm will be included
turn signal cam broke
Cancel cam & spring included
Column same length as a truck
Shaft sticks out the bottom same length as a truck
Neutral safety switch needs to be relocated if your using it
This is a great candidate for someone looking to make a 4 speed tilt column for cheap.
$175 shipped
Thanks,
Tom
Dealer for:
American Auto Wire
Precision weatherstripping
Dakota Digital
Trim parts Carpets
Truck World seat covers
& Many others
Chevy Parts locator in Mesa AZ!
t korinek is offline   Reply With Quote
Old 01-16-2011, 02:47 AM   #2
project 67 sub
project 67 sub's Avatar
Re: Tilt column
good deal for someone, sure wish i had the money for it
project 67 sub is offline   Reply With Quote
Old 01-16-2011, 03:46 AM   #3
70shortfleet
70shortfleet's Avatar
Re: Tilt column
Is the pin still tight on the shift lever? How about $150 shipped?
70shortfleet is offline   Reply With Quote
Old 01-16-2011, 03:53 AM   #4
t korinek
Truckin' Krazy
t korinek's Avatar
Re: Tilt column
70shortfleet, pin is tight, gonna stay at $175 for now.
Thanks,
Tom
Dealer for:
American Auto Wire
Dakota Digital
Trim parts Carpets
& Many others
Old 01-17-2011, 03:15 AM   #5
72shortstep
lovin' the lowcountry
72shortstep's Avatar
Re: Tilt column
Interested, what would be needed to turn this into a 4speed column?
Chris
29461
72 SWB stepside
71 SWB stepside
DRIVE IT LIKE YOU STOLE IT!
72shortstep is offline   Reply With Quote
Old 01-17-2011, 03:57 AM   #6
t korinek
Truckin' Krazy
t korinek's Avatar
Re: Tilt column
72 shortstep, Pretty much the ability to do a little fab & body work, you just do away with the shift lever & grind off the piece sticking out & then JB weld the hole shut, & cut off the selector at the bottom that the auto linkage used to hook to.
Dealer for:
American Auto Wire
Dakota Digital
Trim parts Carpets
& Many others
