01-16-2011, 09:44 PM | #1 |
help with details of 68 c20 4x4
hi.got a truck the other day just so i wouldnt go to crusher.now im trying to part it and hope i at least break even.anyway,what i want to know is stuff like what motor,tranny ect.theres no paper in the glove box to tell me.i'm gonna say it has a :
307? rockwell transfer case 4 speed tranny...dont know the model closed knuckle dana 44HD front end rear is a big round 10 bolt.3 bolts on top,three on bottom,2 on each side(if that makes any sense) have no idea of ratio or even what was available in 68. so thats what i need help with. thanks.
67 chevy c 10 2x4 350/700r4 short/fleet 90 Chevy 1500 4x4 350/5 spd short/fleet 90 Chevy 454 ss 93 chevy camaro z28 auto t-tops 2013 Chevy Silverado LT CCSB 4x4 |
01-16-2011, 11:47 PM | #2 |
Re: help with details of 68 c20 4x4
Transmission will be a SM465 and the axle is the Corporate axle referred to as the HO52. It would be a 4.10,4.57,or maybe deeper. With the 307 I'm betting 4.57. I'm pretty sure that would be a 307. I'm drawing a blank. Does it have an oil fill in the front of the intake?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-17-2011 at 05:07 PM. |
01-17-2011, 11:05 AM | #3 |
thanks. at least it gives me an idea and place to start.vin number didnt tell me much.
01-17-2011, 12:50 PM | #4 |
What?
Engine could very well be a large journal 327, though one of the choices in 68 for the K20 was a 307 engine. The 327 was a upgrade option.
The transfer case is a Rockwell T-221 The transmission is a SM465 The rear axle is a full floater Eaton H052 The front axle is a Dana 44 Gear ratio is more than likely 4.57 1968 K20's are kind of scarce.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
01-17-2011, 05:12 PM | #5 |
Thanks for straightening me out,Vectorit. Does this truck have the SPID? If so and no engine is listed,and the VIN starts with KE2,the engine would be a 307 which will have the oil fill into the driver side valve cover. If still original the oil fill will be in the rear with a tube extending up next to the air cleaner.
01-17-2011, 05:30 PM | #6 |
like stated above there was nothing in the glove box.i looked today and the oil fill is in the front. center of the valve covers. i included a pic.thanks.
67 chevy c 10 2x4 350/700r4 short/fleet 90 Chevy 1500 4x4 350/5 spd short/fleet 90 Chevy 454 ss 93 chevy camaro z28 auto t-tops 2013 Chevy Silverado LT CCSB 4x4 Last edited by dishow; 01-17-2011 at 06:00 PM. |
01-17-2011, 06:04 PM | #7 |
What?
NP Special-K.
Not sure how you could tell a 307 from a 327 from a distance, since they are practically identical from the outside. I can say that my original 327 has an oil fill tube in the intake manifold, just in front of the water neck. A large journal 327 will have a larger harmonic balancer, and it won't have a vent next to the distributor in the block. Everything else on the engine could have been changed out in it's life time, such as brackets, valve covers, intake manifold, or exhaust manifolds. The heads as well. But, it they don't have mounting holes in the front of them for brackets, then they are the older versions that could be original to the truck. (smaller valve types, which in IMO work best in this kind of set up). Here are some notes I have, and in no way am I implying that these are gospel. Just notes of mine I picked up some where, and maybe they can help you out. SBC BLOCKS CASTING#.....SIZE...YEAR...MAIN CAP BOLTS....NOTES 3858174....327...64-67...2 3858180....327...64-67...2 3858618....350...68-76...2 3862194....283...65-67...2...Chevy II recessed oil filter boss 3862812....283...62-64...2 3892657....302.....67....2...Z-28 Camaro 3892657....327.....67....2 3892657....350.....67....2...Camaro 3896944....283...66-67...2 3896948....283...66-67...2 3903352....327.....67....2 3914636....307.....68....2 3914638....307.....68....2 3914653....307...68-73...2 3914660....327.....68....2 3914678....302.....68....2...Z-28 Camaro 3914678....327.....68....2 3914678....350.....68....2 3931174....307.....68....2...Truck 3932371....307...69-73...2 3932373....307...68-73...2 3932386....302.....69....4...Z-28 Camaro 3932386....327.....69....2 3932386....350.....69....2 or 4 3932388....327.....69....2 3932388....350.....69....2 or 4 3933180....327...68-69...2 These numbers are typically found on the bell housing portion of the block. Other tip offs, would be a heavy duty radiator, upper radiator hose made of metal, canister type oil filter, four barrel, but again this stuff can disappear over time. So, unless you can decode the castings, which are not a 100 percent bet on what you may have. The only way to know for sure is to disassemble the engine.
01-17-2011, 06:09 PM | #8 |
What?
you posted a pic while I was typing up that long winded response...
Those heads look period to the truck. Personally... The air cleaner, and two barrel carburetor would sway my opinion towards a 307. Can you post a picture of the harmonic balancer? That would rule out small or large journal.
01-17-2011, 06:14 PM | #9 | |
