01-17-2011, 05:06 PM | #1 |
Ram horn manifolds w/s10 swap?
Anybody had any luck running ram horns with a sbc in a s10 swapped AD truck?
these are the ram horn manifolds I'm referring to... |
01-17-2011, 08:24 PM | #2 |
Re: Ram horn manifolds w/s10 swap?
I tried the straight down ones and it was a no go... simply due to engine mounts and frame spacing... the angled ones may work...
Are they the 2" or 2 1/2" version (I hear the 2 1/2" ones are better for mid/top end and the 2" on the low end, not that I have any experience in it... just what I've read). I ended upgoing with a set of cut down flowtechs... Cheers! Ted.
'51 Chevy Build - In the design stages Aut viam inveniam aut faciam - I will either find a way or make one. If you don't have time to do it right the first time, when will you... My new build - https://67-72chevytrucks.com/vboard/...70#post8958970 |
01-18-2011, 07:25 PM | #3 |
AD Addict
Angled ones don't work either. They hit the A arms. Tried it on mine with engine in stock position and one back almost 2" back.
01-19-2011, 01:53 PM | #4 |
Thanks guys, I know my engine is mounted lower than others and a few inches back too.... so I doubt they will work for me either.
01-19-2011, 02:58 PM | #5 |
vintage car junkie
Yaril is running them on his truck, not sure which style though.
http://67-72chevytrucks.com/vboard/s...=387472&page=3
1950 chevy truck, s10 swap, bagged, v8, 18s My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761 |
01-19-2011, 06:12 PM | #6 |
I totally forgot he had them on that build... I might have to do some measuring now.
01-19-2011, 08:42 PM | #7 |
AD Addict
I think he must have the engine up a bit. They aren't working on the stock motor mounts on my S10. I also have crash issues with the fuel pump. Might be a good idea to PM him.
01-19-2011, 09:04 PM | #8 |
Yeah mine is far enough back that I can't run a mechanical fuel pump because it hits the crossmember.
Posted via Mobile Device |
