01-18-2011, 12:07 PM | #1 |
Heater Wiring
Soooooo.... the previous owner installed an aftermarket heater and now I am trying to put a stock one back in..... I have the harness (1 plug for the resistor, 1 plug for the back of the controls, 1 plug for the blower motor, AND the mystery wire.... Im guessing it most likely going to go to a switched positive? Is this correct? Also, Is there no ground wire?? Thanks in advance guys....
01-18-2011, 12:22 PM | #2 |
Re: Heater Wiring
You should have a long orange and or pink wire that plugs into the fusebox. Is this the mystery wire?
01-18-2011, 12:32 PM | #3 |
Project Junkie! Fishing Poor!!
Re: Heater Wiring
If you are trying to go back to stock then what you have will not work. You should have a harness that has a 4 prong plug that has 3 wires that got to the resister and the (positive) brown wire under your dash will plug into that 4 prong plug also. (The brown wire gives power to the systom) Now the 3 other wires will go into a plug that leads to the resister, with one wire (orange) coming out of that plug leading to the heater motor. Then there is a short grounding wire that goes under one of the fans mounting screws to the one of the upper housing mounting screws. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
