4x4 vs. 2-Wheel Drive Frame ?'s
Is the frame in the front the same for the 4 wheel and 2 wheel drive models? I know that the crossmember to hold the suspension is different on a 2 wheel drive, but was wondering about the basic frame. I am thinking about some things, but it may not be practical. Thanks for your help.
mark
1970 GMC Burb 4x4 - 68 Chevy Front, FI LT1, 4L60E 1970 Chevy Impala 47,000 miles 2001 BMW 540i 6-speed 2002 Dodge Ram 1500 4x4 w/20's |
L.E.D. Freak
Yes the basic frame is the same just different holes/rivets installed. I took a 4X4 blazer and slapped a 2wd front crossmember under it. That should tell you. Just had to drill a few more holes for crossmember, and space the idler arm out from frame a bit.
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
Thanks Reumster. That gives me another option to go. Any LED's for the Burbs yet, or will the truck ones work. I would like to do this mod sometime soon if available.
L.E.D. Freak
Yes the fleet side inserts work with Subs, you just need a peice of foam to make up for the extra room of the sub lense. Simple
Could you elaborate on the foam idea?
