Old 01-20-2011, 07:12 PM   #1
68Stepbed
68Stepbed's Avatar
Am I just nuts?
Ok, a couple months ago, I upgraded to 17" wheels from 15" wheels. I really like the look of the new wheels and all, but I don't like the way it seemed to have altered the stance. It seems as if it sits a bit taller with the larger wheels. My truck has a 3.5/5 drop and I've always liked the stance, but it also always had 15's. Now, though, with the 17's, I find my self wanting it to sit a bit lower(about an inch) all around.
I'm thinking of switching to a 2" front spring and getting a 1.5" block for the rear. I can have the blocks for the rear machined if it's too much. I may have it machined with about a 4 deg. angle to adjust the pinion angle as well.
What do you think? Am I just ? Or do you agree?
With 17's now.
How she sat with 15's.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-20-2011, 07:15 PM   #2
speedfreak369
speedfreak369's Avatar
Re: Am I just nuts?
looks fine i would leave it... it is a beautiful truck
speedfreak369 is offline   Reply With Quote
Old 01-20-2011, 07:54 PM   #3
treveiger
treveiger's Avatar
Re: Am I just nuts?
I think the rims changed the look of your truck more so than anything else with the stance. Maybe your just not use to it?
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 01-20-2011, 07:59 PM   #4
lakeroadster
Re: Am I just nuts?
Probably the difference in tire side wall height that makes it appear higher to you.
To me it looks ideal just as is and it looked good before, too!
Is that an SNJ in the one picture? What's the story there?
lakeroadster is offline   Reply With Quote
Old 01-20-2011, 08:08 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Am I just nuts?
I like the 17's much better.
Do you think you can lower it any more, without creating rubbing issues?
Looks like the wheels stick outside the fenders, slightly.
Keith
Convert to disc brakes.
Old 01-20-2011, 09:13 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Am I just nuts?
It looks horrible -- you should get rid of it quickly, and for a pittance. I can be there soon (at your convenience, of course) to take that poor homely beast off your hands.
Ahhhhhh, who am I kidding, it looks fantastic. Like treveiger said, maybe you're just not used to it yet?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 01-20-2011, 09:20 PM   #7
Hezie
Hezie's Avatar
Re: Am I just nuts?
Matt,it looks like your overall tire hight is smaller which will give you more space between the tire and fender opening and make it look higher.You already know what I would do.And of course I love the new wheels.
Hezie
My Build
http://67-72chevytrucks.com/vboard/s...d.php?t=375244
Hezie is offline   Reply With Quote
Old 01-20-2011, 10:50 PM   #8
dubds10
Stalker Nate
Re: Am I just nuts?
How about you give us the specs to both tire sizes...then it'd be easy enough to figure out if anything actually did change. Looks the same to me though. Much better with the 17s too.
dubds10 is offline   Reply With Quote
Old 01-21-2011, 09:59 AM   #9
68Stepbed
68Stepbed's Avatar
Re: Am I just nuts?
Well, the front tire dia. is the same at 27" 255/60/15-255/50/17. The rear tire is a bit taller than the old ones. 275/60/15(28") 275/55/17(29")
I guess you're right. I may just need to get used to them. I know I can go lower without the tires rubbing, but I will have to change my exhaust, which I need to do anyway. The bozo that did my exhaust didn't do a good job and it rubs and bumps in a couple places anyway. Going lower would make it worse, though, if not corrected.
Lakeraodster, SNJ? Are you asking about the plane?
Matt
Old 01-21-2011, 10:07 AM   #10
lakeroadster
Re: Am I just nuts?
Yep, the plane.... (Navy) SNJ a.k.a (USAAC)T-6 Texan http://en.wikipedia.org/wiki/T-6_Texan
Old 01-21-2011, 11:12 AM   #11
jborders
jborders's Avatar
Re: Am I just nuts?
I just changed to 22s from 15 inch wheels and was thinking the same thing about mine. The tire is the same o.d. as my older ones were but it just doesn't look right to me. I'm thinking about lowering it another inch or two as well. It must be something about the shorter side wall that makes it stand out more or something.
jborders is offline   Reply With Quote
Old 01-21-2011, 11:14 AM   #12
glider_6969
Re: Am I just nuts?
I tend to argree with the guys here, that's a great looking truck,, It wouldn't take much for me to get use to it
glider_6969 is offline   Reply With Quote
Old 01-21-2011, 01:03 PM   #13
ls1nova71
ls1nova71's Avatar
Re: Am I just nuts?
Personally, I think it looks great, and wouldn't mess with it. But if you do, you might want to put pinion angle guage on it first to see how much angle you really need, 4 degrees sounds like a little too much.
ls1nova71 is offline   Reply With Quote
Old 01-21-2011, 01:19 PM   #14
68Stepbed
68Stepbed's Avatar
Re: Am I just nuts?
Yeah, I'm just guessing at the pinion angle. I'll definetly check it before actually having the shims made or what not.
Lakeroadster, yep, it's a T-68 training plane. It's at a local Warbird museum. www.tnairmuseum.com
I went to get pics with this A1H Skyraider, but he didn't have it out.
I appreciate everyone's opinion. I may leave it alone for now and try to get used to it. If it keeps bugging me though, I may end up lowering it a tad more.
Matt
Old 01-21-2011, 01:33 PM   #15
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Re: Am I just nuts?
I would leave it, looks great in my opinion!
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-21-2011, 01:51 PM   #16
tubbedII
needs more $$$
tubbedII's Avatar
Re: Am I just nuts?
Although I think it looks great as is, I would drop it another inch as long as there's no rubbing issues. I perfer little to no wheel gap. I think you have it right too with the 1" in front and 1.5" in the rear additional drop. I think with that it'll still have a good looking rake to it.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-21-2011, 02:44 PM   #17
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
Re: Am I just nuts?
Let me start by saying I love your truck,one of my favorites on the site.As far as the rims I like the old school look of the 15,s more tire less rim.
The Dude Abides.
I aint sayin, I'm just sayin.
1970 Bowtie is offline   Reply With Quote
