01-20-2011, 10:24 PM | #1 |
Decided to step notch my frame and more
Decided to just get my rear level with the front. Frame rails are 2x4x3/16, wanted abit heaver so it would ride better. Trailing arms are 2x2x1/4 with adjustable bushings.
Rusty driveshaft is just for mock up right now, pulled from a junkyard since I needed a smaller diameter. Everything will be fully welded, grinded and smoothed before painting. |
01-20-2011, 10:28 PM | #2 |
Re: Decided to step notch my frame and more
more
01-20-2011, 10:34 PM | #3 |
more
01-21-2011, 12:38 PM | #4 |
needs more $$$
Looks good! I never knew your truck didn't sit level...
1970 2wd Blazer |
01-21-2011, 01:28 PM | #5 |
I like the holes.... I'll prolly be doin a lot of flared holes with my chopped and bagged 64' build.
01-21-2011, 10:20 PM | #6 |
thanks guys, its coming together slowly
01-21-2011, 11:51 PM | #7 |
One day...
Looking good!
01-22-2011, 10:49 AM | #8 |
I like the speed holes. My advice though would be to use them sparingly, dont go crazy with too many, everywhere...
01-22-2011, 12:19 PM | #9 |
67cheby
looks awesome
01-23-2011, 11:27 AM | #10 |
It'd be alot cooler if you did
What are you using for a trailing arm? They look pretty small.
01-23-2011, 07:41 PM | #11 |
01-23-2011, 11:05 PM | #12 |
looking good you need to come visit up this way some time
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
04-20-2011, 10:40 PM | #13 |
slowly coming together all wiring, air line and fuel line routed thru the frame
04-20-2011, 10:42 PM | #14 |
more
04-21-2011, 08:12 AM | #15 |
One day.....
Man that looks nice!!!
DZL1. |
04-21-2011, 08:35 AM | #16 |
nice work
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
04-21-2011, 09:54 AM | #17 |
Man you do good work, fabrication and painting looks awesome.
I wanted to mention that the strength of the 2" x 2" x 1/4" trailing arms is marginal. The analysis I ran is based on the air bag seeing a 1500# load (the approximate weight of the truck at the rear axle). This assumes all the weight on one bag (realistic shock loading from pot holes, speed bumps, etc.). Safety Factor for the 2 x 2 x ¼” tubing is 0.86. In comparison, a stock trailing arm Safety Factor, also using 1500#, is 3.0. I don’t want to be a “buzz kill” but felt compelled to mention this. If the air bag wasn't monted on the 2" tubing it would be just fine as a ladder bar, the weight on top of such a relatively small section height structural member is the problem. John Last edited by lakeroadster; 04-21-2011 at 09:55 AM. |
04-21-2011, 09:43 PM | #18 | |
04-21-2011, 10:02 PM | #19 | |
...and btw, it looks awesome painted!! Last edited by Mkcustums; 04-21-2011 at 10:03 PM. |
04-22-2011, 08:14 AM | #20 |
Just trying to help ya and others here on the board too.
I'd rather say something so you can keep an eye on it, as opposed to it failing and leaving you scratchin' your head along the highway somewhere. There are also a lot of fabricators on our site that base there future or current builds on what they see here, this allows them to consider using something more substantial than the 2" x 2" x 1/4". Sorry if my post offended you. John |
04-21-2011, 09:54 AM | #21 |
67cheby
Clean work looks SMOOOOTH
04-22-2011, 05:03 PM | #22 |
↑↑↑ I think it was a very valid point to make, don't feel bad about what you said, it's just the truth. I've seen you make comments like that before and it's helped others out!
04-22-2011, 10:54 PM | #23 |
looking good
04-22-2011, 11:48 PM | #24 |
Is the frame painted from the cab forward? If so you should put some pics of that too. I'm not a big fan of red, but I like the way that looks!
04-23-2011, 01:26 AM | #25 |
looks really nice man!
