Old 03-12-2003, 06:55 PM   #1
john j
New guy
Hello from the state of NH. My name is John but they call me JC. Don't know why , but they do. I've been here for 8 1/2 years. I moved from sunny Calif. and remarried. I have 3 daugheters and one son. 9 grandchildren. My project is a 58 3/4 ton that has been in the family since 62. Many great memories in her with my dad. I am not sure if i am going to 4x4 it or slam it. I do know that a small block and automatic is the way iam going. Iam looking here for a 1/2 ton front axel set up now. I don't want to change from the Ibeam axel. I have a question on the motor mounts. If you use the stock front mounts,on the front of the block, do you have to make some for the back of the block? I know you can use a trans mount on the tail housing, but wat about where the block meets the trans. Any and all input is neede. Thanks
john j is offline   Reply With Quote
Old 03-13-2003, 12:26 AM   #2
ljbear
ljbear's Avatar
JC
Welcome to the board. The rear is usually supported on the bell housing by a cross member. If you want to suspend it at the rear consider using a side mount on the block. There are several companies that have kits that move the mounts to the frame and let you use the 3 holes in the block.
Larry
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
