01-22-2011, 10:43 PM | #1 |
rear big wheel question
On a 67-72 truck, what is the widest wheel you can run without having to get rid of the trailing arms? Wheels in mind are 22x12 with a 4 inch backspace. Narrowing the rearend is something I dont mind and know it will have to be done more than likely. You guys let me know so I can relate the info. to my brother.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
01-22-2011, 10:54 PM | #2 |
Re: rear big wheel question
Ive got 22x12 in the rear with ride tech trailing arms and there is tons of clearance. I do have a mini tub but even with stock arms you should have plenty of room.
01-23-2011, 04:12 AM | #3 |
can I see?
-1969 C/10 Short Step soon to be Brand NEW Ls6/T56 -03 Mazda Protege 5 -WTB 1970 Chevelle project |
01-23-2011, 05:33 AM | #4 |
69' Chevy Stepside
Mine has 15x10's and pretty big rear tires and its really close to rubbing on the inner fender/bed, with stock rear trailing arms and lowered with springs and a adjustable trac bar.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
01-23-2011, 03:30 PM | #5 |
is the stepside really different from the fleetsides?
01-23-2011, 08:44 PM | #6 |
pics so you can see the 22x12
01-23-2011, 11:21 AM | #7 |
I'm running 20 x 12's with a 7" backspacing and a 31-16 tire. I'm not anywhere close to the trailing arms. Here'a few pictures:
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-23-2011, 02:17 PM | #8 |
01-23-2011, 02:55 PM | #9 |
I had a buddy make it for me. It's similar to the ones that FuelCell guy sells, but we modified it to have the sump in the back.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-23-2011 at 02:58 PM. |
01-24-2011, 02:09 PM | #10 |
01-23-2011, 03:08 PM | #11 |
01-24-2011, 02:31 PM | #12 | |
Rob I LOVE that truck! I was wondering, does it still has the narrow rear end?
1968 C10 LS2/4L70e swb fleet side. ECE front disk conversion and 3.5/5 drop. SOLD. 1968 C20 Custom Camper 396 50th survivor! SOLD to northerngmc |
01-24-2011, 05:16 PM | #13 |
Thanks, it's got a factory 68 rear end.
01-25-2011, 12:43 AM | #14 |
What do you have to do to be able to run a 22x12 with a 4 inch backspace?
01-23-2011, 12:15 PM | #15 |
if you tube it you can run a 15x14 - 10" bs w/ 31x18.5 tire and still clear the arm.. not sure how big ya can go if you keep the stock tubes....
04-08-2011, 03:36 PM | #16 |
Hart_Rod and C10Seconds, do you guys have any rubbing issues on the fender(outer) side of the tire?
04-08-2011, 05:50 PM | #17 |
I had slight rubbing when I had the wider 71/72 rear installed. None whatsoever with the narrower 67-70 rear end.
04-09-2011, 05:36 AM | #18 |
Same here. Im using the 67 rear end and there is no rubbing at all
Posted via Mobile Device |
04-09-2011, 06:35 AM | #19 |
Sweet! I shouldn't have a problem stuffing in a wide wheel in the rear on my '68 then!
Thanks for the feedback guys! Hey C10, any more pics of your truck with the 22's like in your avatar...? |
