01-22-2011, 11:55 PM | #1 |
fuel gauge issue
so i went to fill my tank the other day, and the pump shut off like the tank is full. but the gauge only went to a little over 3/4 full. tried filling the other tank, same thing. gauge only goes up to a little over 3/4 full. this just started, never had an issue in the past. anyone have any suggestions? i sure would like to know how much gas i have left lol
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
01-23-2011, 04:40 AM | #2 |
Gettin It One Pice At A Time
Re: fuel gauge issue
Subscribin and a bump!
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
01-23-2011, 04:43 AM | #3 |
Desert Rat
Does it stay in the same place no matter what?
01-23-2011, 04:45 PM | #4 |
no the gauge goes down, it just won't go all the way to full. which is annoying cuz i don't know exactly how much fuel i have...
it has to be something wrong with the gauge or the connections to it right? cuz it does the same thing which ever tank i fill.
01-23-2011, 10:41 PM | #5 |
My fuel gauge had the problem at the other end - would only go to 1/4 full on both tanks, then would start working when the tanks were actually 1/4 full. My guess is you need a fuel gauge like I needed one - $50 + shipping will answer your question for sure.
01-23-2011, 10:42 PM | #6 |
where did you buy yours? and maybe i'll try a few from the pick n pull
01-24-2011, 10:26 AM | #7 |
Pretty sure if you ground out your sending wire it should read full. Mine was always full because I had a short in the wire. Replaced it and it worked. Now my other side is still saying always full and I haven't figured out the problem with that one yet but at least the one works.
01-24-2011, 02:54 PM | #8 | |
i might go to the junkyard today and grab like 4-5, and tell the guy at the counter i need find one that works and will return the others.
01-24-2011, 03:36 PM | #9 | |
Conversion Truck Addicted
dont think its your fuel gauge but i might be your filler it self seach back a pages for how to pump fuel or something like that its a common problem on the early square bodys
Thomas Quote:
01-24-2011, 03:43 PM | #10 |
These are 0-90 ohm senders. An open circuit (infinite resistance) will read past full and a short to ground (zero ohms resistance) will read empty. If both tanks are acting the same it must be something they both have in common such as the selector switch or the gauge.
I'm leaning towards the gauge.... Posted via Mobile Device
CHEVY ONLY Last edited by joe231; 01-24-2011 at 03:44 PM. |
01-24-2011, 05:14 PM | #11 |
Yeah, in retrospect, there's almost no way for both sides to go wrong exactly the same at the same time so.... I'd say gauge too. As for the wires, I think it's blue for the left and brown with a white stripe on the right but you'd have to look at what color wire actually goes up to the tank for sure and then pick that color going into the back of the switch in the cab.
Maybe I was backwards on which way they read though. What would cause "infinite resistance"? a completely disconnected wire or... ? |
01-24-2011, 05:32 PM | #12 |
well i just got back from pick n pull, about to swap the gauge and fill a tank. i'll let you guys know what happens
............._____l __\__ ..............l_(O)_ l___(O)] Last edited by GMC Guy; 01-24-2011 at 05:33 PM. |
01-25-2011, 01:35 PM | #13 |
turns out not to be the fuel gauge. but the connection from the circuit board. i really am tired of dealing with bad connections due to a 30+ year old circuit board...i really want to buy a new one ($70) but i think i should give pick n pull another try. they had a bunch on 78-80 clusters out there, so hopefully one will work better than mine
01-27-2011, 05:33 PM | #14 |
any luck yet?
Turns out I was wrong. both my tanks are messed up. Wiring seems to be all good but the right tank says 1/4 full and its filled to the top, and the left one say way over full and it's bone dry. I give up. Taking it to a shop on monday and telling them to fix it. May just have 'em replace everything from the sending units all the way up to the fuel gauge itself. I need to get this done and put the cab back together cause it's a damned wreck in there. |
01-27-2011, 08:30 PM | #15 |
ya it was a bad connection from the sender to the gauge. so i just went ahead and hard wired the fuel gauge, along with the voltmeter and oil pressure gauge while i was at it. works flawlessly now
01-27-2011, 09:47 PM | #16 |
Im having an issue where it reads i have a 1/4 tank ive switched with 3 gauges that i have lying around and one other reads the same 1/4 full and another goes like way past full by an inch or so.... You say you hard wired it?How? mines a 87 is mine different ? i also would like to know how much gas i have in it.
01-28-2011, 01:05 AM | #17 |
there's three connections that need to be made on the back of the gauge.
1. a switched 12 volt source 2. ground 3. and a connection from the sending unit. this usually is 2 pink wires on in the main harness connection to the gauge cluster. (at least mine was)
............._____l __\__ ..............l_(O)_ l___(O)] Last edited by GMC Guy; 01-28-2011 at 01:07 AM. |
