Old 01-23-2011, 11:09 AM   #1
NCD1966
NCD1966's Avatar
68 camaro headers on my 66 stepside
I'm in the process of installing a 350ci bored .030. And the heads and cam like bigger tube headers.
I have some new 1968 camaro Headman Hustler headers 1-3/4 tubes. with 3" collector.
My truck is lowered by the jeep coils in rear and cut coils in front. So I dont think ground clearance is a issue. Also Im running a Saginaw 3speed with overdrive.
Any of you guys know if this will work?
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 01-23-2011, 11:13 AM   #2
shortbed70
shortbed70's Avatar
Re: 68 camaro headers on my 66 stepside
I run a set of summit LT's from a 67-81 camaro with my automatic and had to trim about 1/2" off the pass side rail to clear the header tube. On a stick truck I dont know how they will play with the linkage. Mine are 1 5/8 tube also.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 01-23-2011, 11:30 AM   #3
NCD1966
NCD1966's Avatar
yeah i have some Long tube that are 1-5/8 that have been on my truck for a long time.
I guess Ill just have to try the camaro ones and hopefully do very little mods.
Old 01-23-2011, 12:31 PM   #4
shortbed70
shortbed70's Avatar
It should work and not hang below the frame much
Troy
Big Red Dog build
Old 01-23-2011, 11:51 PM   #5
Captainfab
60-66 Nut
You will likely have clutch linkage and bellhousing crossmember interference.
Old 01-24-2011, 06:03 AM   #6
Rannos
Rannos's Avatar
When I installed long tube headers on my 64 with a 3spd I had trouble with the clutch linkage not fitting. I had to rotate the z-bar back(towards the front of the truck) a ways to clear the last primary and make a new rod from the pedal down to the z-bar. if you go this way just remember to leave adjustment in the rod to fine tune your pedal to clutch travel. When you change the rotation of the z-bar it changes how much it pushes on the clutch fork. If not done correctly you end either with short pedal travel and possible slipping clutch or not enough travel to disengage the clutch completely.
Rannos is offline   Reply With Quote
