01-23-2011, 11:03 PM | #1 |
lmc heat and sound deadener kits
Hi guys, I know there has been alot of discussion on the site about this. I am doing a interior rehab on the 68 p.u. I am on a budget ( child in college ) so money is tight. I will not have a heater/defroster unit in the truck after the rehab. Has anyone used the eva sound deadener and heat shield kits from LMC?. Any luck with them?. I would like to use the other items mentioned on the site but like i said i have to watch the budget. thanks Russ
01-24-2011, 02:48 AM | #2 |
Re: lmc heat and sound deadener kits
Hi Russ, I did my cab a few months ago. Started 2 rolls of 6" butyl rubber window sealer instead of spending a lot of cash on very spendy Dynamat, ($18 at Home Depot.) Cleaned all the metal with grease and wax remover. Then stuck the rubber down everywhere including the back wall. Next I added the pre-cut LMC sound deadener "kit". It's basically very thick tar paper. Over that I layed the insulated heat barrier from LMC. Then over that my carpet which had more padding but only under the front part. It didn't have it on the carpet that goes under the seat. Padded and carpeted the back wall too as I have no gas tank inside anymore.
Kevin Last edited by kevmcrae; 01-24-2011 at 02:50 AM. |
01-24-2011, 11:09 AM | #3 |
Just know that the home depot stuff will work great! some people say it smells like tar sometimes. but non of that foil stuff is a sound deadener really....it stops rattels doenst really stop the sound waves, you need like a CCF closed cell foam for that...which is cheaper!
-1969 C/10 Short Step soon to be Brand NEW Ls6/T56 -03 Mazda Protege 5 -WTB 1970 Chevelle project |
01-24-2011, 05:45 PM | #4 |
Hello MWILLIAMS5891, thanks for the info,, where would i buy and what is CCF closed foam cell...Thanks...Russ
hello kevmcrea, Thanks for the info. It really helps that to know that other people used it...thanks Russ |
01-25-2011, 12:04 AM | #5 | |
stay away from dynamat waste of money!!!!! go here http://secondskinaudio.com/
01-25-2011, 01:15 AM | #6 |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-24-2011, 10:41 PM | #7 |
I'm going to put this in my "interior info" thread...
Have mercy, I'm recovering from my 4x4 addiction. |
01-25-2011, 12:24 PM | #8 |
I am going to check out this B-Quiet deal. 50sq foot at 89 dollars is a helluva lot better than 250 for the dynamat. It looks like the same stuff.
70cst how well is it working for you? do you like it. was it pretty easy to use. Give us the scoop on this. Thanks
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. Last edited by roughedup72; 01-25-2011 at 12:24 PM. |
01-25-2011, 12:32 PM | #9 | |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 01-25-2011 at 12:33 PM. |
01-25-2011, 06:45 PM | #10 |
Thanks for the guys, Iwa thinking of using lizard skin but we need other things around the house. 70cst, I like the idea of using B-quiet. mwilliams5891 thanks for the explanation, will be checking secondskin out...Thanks
