Dual Fuel Tank Conversion
Hello I've got an 83 SWB it came with a single tank I'm curious if it would be worth the trouble to try and install a second tank in this thing. Or would it just be easier to just install a 22 gal fuel cell in the bed?
BAD BOW-Silverado XST
Re: Dual Fuel Tank Conversion
Welcome to the site. Why not add 45 gallons!! Yea!! You can add a suburban or Blazer tank where the spare tire mounts!
Blazer tank install: http://www.captkaoscustoms.com/blazertank.html Fuel cell: http://www.73-87.com/7387garage/chas...ellinstall.htm I have dual tanks on my 83. Cruise range is almost ~275 miles per tank! 500+ miles with both full tanks if I keep my foot out of it. Get a catalogue from www.lmctruck.com. You can find all the stock parts you need. You will need to add a second fuel door or swap beds. I replace the origina bed on my truck. I found a single tank SWB bed. I had the passengerside fuel door added to the replacement bed. Last edited by gchemist; 01-24-2011 at 05:45 AM. |
Well when I did the body work on the truck I had to replace the pasenger side bed side I went ahead and got the one that had the fuel door in it. What all would I need to add. I know the selector valve, tank, fuel line and the switch inside the cab. Is there any pictures of the factory setup or some kind of diagram?
In the Forgotten far North.
![]() Join Date: Jul 2007
As far as the wiring goes if it were me, I'd locate one in a wrecking yard that had what I need for the wiring harness, carefully disconnect and remove it all without cutting anything anywheres then reinstall it all into my truck.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
I own a 83 dual tank 4x4. I wont be looking at til spring though.
I would do the blazer/burban tank..stockish look and cheapper id say, i already have the twin tank set up and they are nice but they are small as well
Yah I'm wanting a few more miles out of it in between fuel stops, the one 16 gallon tank does not go very far in these things...kind of guess it would if I would keep my foot out of it. I will go and look through some of the salvage yards and see what I can find. When the 700r4 goes in next week it should help out a little.
