![]() Join Date: Oct 2005
Lockers???
Dana 44 front ho52 rear...Where can I get some lockers??Any experiences??
WTB 1972 CHEVY 3/4 4X4 1971 chevy c30 4x4 NAPCO (project) 1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers 1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete 2006 chevy LBZ crew cab duramax,4 inch,beadlocks 2015 chevy tahoe Z71 my fifth one,love em 2016 chevy 2500HD Z71 LTZ duramax midnite 2018 chevy suburban Z71 midnite |
Re: Lockers???
Google search "Dana 44 lockers" and you will get more than enough info. Find what you want (mechanical, air, electronic, cable) and then find the best price - just depends on what you're looking for.
Completeoffroad.com is one place... As for a Ho52...I don't know but I found this: http://67-72chevytrucks.com/vboard/s...d.php?t=182961 I would just swap in a 14bolt for more readily available parts and better aftermarket. Good luck. |
Re: Lockers???
Factory no-spin for the HO5200 if you can find one. But I think you can swap the 14 bolt locker in if you use the 14 bolt axles. Obviously you need to find a 14 with the correct length (or close!) axles or buy some cut-to-length aftermarket ones.
Re: Lockers???
Ihave detroit true tracs front and rear in my CJ5 and they do real well, can not even tell they are there but all four tires spin in 4 wheel drive.
Will probaly install one in the rear of my 70 GMC 4x4. Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
Re: Lockers???
Ordered a detroit true trac locker last nite... d44 ..thanks for the suggestions....
Re: Lockers???
You'll like that up front. That's what I run. Keep an eye on the parts board for an HO52 No-Spin. I've bought two from Teeitup. You can have the drop-out diff sent and just bolt it in. It's worth the extra shipping IMO.
