01-25-2011, 11:59 PM | #1 |
Extreme Drops
Ok... Those of you w/extreme drops, if your truck (or your car) is dropped alot (trucks @ 6/8 minimum), I'm looking for some honest, real world answers.
Specific to these trucks, Dropmembers, Scott's IFS, Z's, and/or other chassis mods can get you inches off the ground & do look sweet. Beyond that, how much do you really drive your vehicle? Do you just do the in town & local cruise nights (bikers call them 'barhoppers')? Power Tour/s? Cross country road trips to board meets? I'm curious as to how many actually put 300+ miles in a single stretch in their extreme dropped 'hot rods'??
01-26-2011, 12:06 AM | #2 |
Re: Extreme Drops
I tell you this. If i ever get my truck back to runnin im going to home depoe an load up some sheet roc. and drive the wheels off of it . lol
nickle and dime |
01-26-2011, 01:00 AM | #3 |
It followed me home?
Re: Extreme Drops
I havent gotten my dually to scrape anything yet, probably because of the 29" tires. I dont even have to slow down for big dips in the road but I do out of habit .
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
01-26-2011, 12:58 AM | #4 | |
Re: Extreme Drops
heavy metal.Drove from Ventura ca to Goodguys indy took 3 days and took on alot of rain with no top it was a complete blast and the crowd at the show thought it was cool as hell. Justin |
01-26-2011, 01:07 AM | #5 |
A guy with a truck
Re: Extreme Drops
Daily drove my '70 for about a year with spindles/springs front and bagged/blocks/c-notch rear. Back and forth to work, daughter to/from school, Home Depot, you name it. It was my only transportation.
My only real problems came when I took it off pavement. Dragged the lowers a few times on driveways/curbs and almost got stuck on a rainy day at the metal scrap yard. All that to say it's do-able, but I'm much more comfy in my Yukon...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-26-2011, 01:58 AM | #6 |
Re: Extreme Drops
I usually don't drive anything normal. All my stuff has been 6/8 drops so I know the in/outs of the daily grind but was curious how many others actually put road trip type of miles w/their Dropmember/Scott's IFS/Z'd set-ups.
01-26-2011, 08:48 AM | #7 |
67-72 parts collector,…
Re: Extreme Drops
I've daily driven a 5/7 drop on a '90 short bed and several 4/6 drops on 73-87 trucks.
Never anything as low a 6/8. So I'm hoping with the extra ground clearance of the Dropmember,... I'll be able to drive my next truck anywhere.
01-26-2011, 09:21 AM | #8 |
Re: Extreme Drops
I'm planning to drive the hell out of my truck when I get it done. If it ever gets done.....
Doug Looking for a 67-72 short bed driver..... |
01-26-2011, 11:14 AM | #9 |
Re: Extreme Drops
ive driven my truck bagged laying crossmember for 5 years, daily driver... z'ed and backhalf for a year. driven from AZ to Co then MS and back to AZ.. just added a hitch looking to tow a trailer which now has my old stepside bed on it
01-26-2011, 11:22 AM | #10 | |
Re: Extreme Drops
Tell me what you did on your driveshaft & how has it worked thus far? How about some recent pics (I remember it going together a while back but haven't seen much recent stuff). Anything significant you'd change in retrospect?
01-26-2011, 12:08 PM | #11 |
Re: Extreme Drops
I've driven my dropmembered truck to houston and back from austin and I take 60 mile round trips to my parents house on a regular basis. I drive it to the grocery store, hardware store, cruise ins, car shows, whatever.
My truck is no fancy show piece but sometimes I do have to trailer it for long hauls if I have alot of friends or family going. I don't have front inner fenders right now so I try to keep it off of wet roads or gravel so I don't get my shiny engine all nasty. I'll be driving it around during the lonestar roundup which is coming up and I'm planning on cruising on over to the texmex show 2 weeks later. |
01-26-2011, 12:17 PM | #12 |
Garage wrench
Re: Extreme Drops
I drive my Suburban daily, except for now when it's salt season up north here. I have maybe an inch and a half between the rear axle and frame and up front it's lowered around 5" or so. I plan on removing the inner fenders and "pancaking" an extra front crossmember I have once spring rolls around. I also plan on running bags all around, maybe some sort of AOL type kit for the rear until I can figure out how to notch it and not lose a bunch of frame strength.
But, for now, when I drive it, it bottoms out all the time. It's actually kind of unsafe I first realized that when I took it for a test run the day I dropped it. It still had the stock 235/75R15 front tires and it bottomed out going around a corner at about 45-50 and I just about went in the ditch. Since then I have gone with smaller front tires but the real fix is to remove the inner fenders and come up with something else. As far as the rear, I have air shocks so I can adjust the ride height a little bit for extra clearance but the real fix is an AOL kit or 4 link or something. Even with all the problems driving it low, I drove it to a car show a few weeks after lowering it. I was about 400 miles, round trip. The ride was a bit bumpy, but I was still grinning the whole time!
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... Last edited by SBTork; 01-26-2011 at 12:18 PM. |
01-26-2011, 05:03 PM | #13 |
Re: Extreme Drops
I drove my '49 30 minutes down the interstate once. .5" off the ground.
after I got most the bugs out I dont see why I can't cruise for days. I even have cruise control I daily drive a 2001 seirra ext cab that is 6/9 on a 30" tire, so it tucks about 1-1.5" tire all the way around. Thats dedication. |
01-26-2011, 11:46 AM | #14 |
Happy to be here
Re: Extreme Drops
Scot- I know you know my buddies Mikes truck that was once owned by Forum member Greens69. You have seen it in the mags, and at lots of shows.
I know it has seen its share of time on a trailer, but the lest two years or so I have seen it driven to a lot of shows. It went to a run in Austin, Galveston, Wolf Creek, and several others with us last year. He does raise it a bit when the roads are rough, but on smooth stretches of pavement I have seen it cruise for many miles just inches off of the ground.
01-26-2011, 12:03 PM | #15 |
Re: Extreme Drops
awesome truck ...
01-26-2011, 12:13 PM | #16 |
Happy to be here
Re: Extreme Drops
01-26-2011, 11:53 PM | #17 |
Re: Extreme Drops
01-31-2011, 10:07 PM | #18 |
Gearhead
Re: Extreme Drops
I drive the s'not out of my bagged 72' C10, 3" drop front arms + the bags and ECE rear bag kit (apx 6-7" drop at the pressure I run) I do run 255/55/18's though....
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
01-27-2011, 12:35 AM | #19 |
Re: Extreme Drops
Once I got my truck all together, I took it for a quick spin around town, about 5-10 miles. The next morning I left here at about 8 AM, heading to Millington, TN for a show. I put about 600 miles on the 67 that weekend, and grinned the entire time. On roads was very familar with, I drove it about a half inch off the pavement. Highway driving and unfamilar/rough roads i was a little higher, but not too much. If I cant drive it whenever I want, I will not have it. To be honest, my issue with my 67 is not if it is road worthy, its that I really need a quad cab so the entire fam can go with me.
01-27-2011, 12:36 AM | #20 |
Happy to be here
Re: Extreme Drops
Welcome to the forum hellbounder.
01-27-2011, 03:15 PM | #21 |
Re: Extreme Drops
01-28-2011, 10:05 AM | #22 |
Happy to be here
Re: Extreme Drops
wheres the pics?
01-28-2011, 07:16 PM | #23 |
Re: Extreme Drops
driven daily 6/8
bagged 87 |
01-28-2011, 11:18 PM | #24 |
Re: Extreme Drops
01-29-2011, 12:02 AM | #25 |
Re: Extreme Drops
I've daily driven extreme dropped trucks before with no problems, but now all of my nice stuff is trailered.
SCOTI , just out of curiousity why the interest in this particular subject? Are you planning on an altitude change on your dually?
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
