Have a 81 scotsdale 1/2t.Are the spindles the same whether it has 1in or 11/12in width rotors.What's the differances.Any body know?Thanks for anything.
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
Oh,you can't buy that new
![]() Join Date: Apr 2000
NOT the same . measure yours to know what you have . 81's are a very tricky year also. lots of left over 80- older suspension parts on them. there was 1" and 1-1/8". DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
They are different. Hollanders gives this info: The 1" thick rotor spindles have a 1-1/4" inner bearing surface diameter. The 1-1/4" thick rotor spindles have a 1-3/8" inner bearing surface diameter. You will have to measure the inner bearing surface diameter to tell the difference. Hollanders shows both spindles were available in 1981 2wd 1/2 ton trucks. I would guess that the 1-1/4" rotors were part of the heavy duty brake option.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
