01-27-2011, 03:58 PM | #1 |
swap to a th350?
Tonight I am going to remove the manual trans crossmember off of my 65 c10. Do you recommend grinding of the clutch bracket that is bolted to frame also?
01-27-2011, 04:20 PM | #2 |
Who Me?
Re: swap to a th350?
Only if its in the way.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
01-27-2011, 04:21 PM | #3 |
I left my clutch bracket in place. I don't think it is in the way of anything. Good luck with the crossmember. It was a huge pain. Lots of patience, a long punch, and a BFH will help a lot. If you're doing it with your cab on, it might be a good idea to use a reciprocating saw to cut the bracket off as close to the frame as you can get in order to provide more clearance for the grinder.
01-27-2011, 04:28 PM | #4 |
thanks guys.
