![]() Join Date: Aug 2010
64-66 Chevy Stock Gauges - Voltmeter vs Ammeter (Batt)?
Anybody put a voltmeter in the stock guage cluster? Maybe in the big hole on the left side (where I'm told the "air' guage was for some bigger trucks)?
1965 Suburban Waiting on Time and Money |
Resistance is Futile
Re: 64-66 Chevy Stock Gauges - Voltmeter vs Ammeter (Batt)?
I have not, first of all......but, I think it would be possible if you find one with a roughly 90* sweep. Most gauges have wider sweeps; I was considering a tach in dash and this is what I ran into. The re-pop vintage tachs have the short sweep but are too expensive for me to hack up to fit in a dash.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#3 | |
Or leave it alone and put a voltmeter under the dash? Roy
1965 Suburban Waiting on Time and Money Last edited by RoyL; 01-29-2011 at 07:22 AM. |
#4 | |
One foot in front of the other
![]() Join Date: Aug 2008
Might try these:
http://www.jcwhitney.com/chrome-2-ra...wx?filterid=j1 http://www.jcwhitney.com/illuminated...wx?filterid=j1 I played around some with the tach- http://67-72chevytrucks.com/vboard/s...95#post4305395 |
#6 | |
Welll- you could send it to me then....
Why's that?? You know how to fix it??
Have no idea- but willing to take alook at it and try.
#10 | |
Roy ![]()
PO had put in the same tach as you . . . It looks like one from Making Waves brand in JC Whitney . . . where'd you get yours? It fits good in there.
Roy JC Whitney as well- around $40.00. And you dont' have to cut up the dash itself. Just the one backing plate. http://www.persh.org/pickup/TachDash.htm |
#12 | |
Think I'm gonna mount a small volt meter under the dash somewhere. Roy
Find yourself a mid eighties GM car with the voltmeter, remove it, take it home and dismantle it by separating the movement from the face, doing the same to your original, install the eighties onto your original face, install into dash pod, thats how they are doing this on the chevelles, I have`nt done it yet but am looking into it.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
From the 1963 GMC Accessories Book. Chevrolet Accessories book had it listed as well.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 03-02-2011 at 11:54 AM. |
#15 | |
I just bought a NOS Bat-O-Meter and a sun tach (less sender) I am in the middle of refurbing a 66 gmc dash and I think this will make it look a lot better. I am trying to use chrome paint to finish it off will advise how it works and looks after everything is finished. Company wanted $200.00 to vacuum chrome it but I think I can do is by soda blasting the plastic, primering it, painting with chrome paint and then clearing it. Worst case I have to send it to them to redo it. Kieth ![]() ![]() |
#16 | |
Cool, where you gonna mount the Bat-o-meter? Roy
#17 |
#18 |
JUST A LITTLE UPDATE: FINAL RENDITION INSTALLED BATOMETER AND SUN TACH 66 GMC.... ![]() http://kieth.smugmug.com/Trucks/66-G...WmmMg&lb=1&s=A IN THE TRUCK: ![]() ![]() http://kieth.smugmug.com/Trucks/66-G...PBQ7f&lb=1&s=A |
#19 |
I went to a junk yard and got the volt meter, have it installed in the cluster cutout thing and ready to install, but how do you hook up the wiring harness to the voltmeter? Did you cut the factory plug and install ring terminals? Any pictures? This is a great writeup, and I tested my gauge before installing. Just hope it all works when I get it back together, haha.
#20 |
Yeah, sometimes, if it ain't broke, don't fix it, works just fine . . .
#21 |
Well there is some thruth to that, but if you`ve ever had a harness fire due to a amp gauge/voltage regulator you`ll never have another one. I lossed a harness in a `62 409 back in `69......man what a mess....
#22 |
be sure to read this as well, shows a better way to retain the meter with tabs and clamp. Should be enough room for a hose clamp . . .
#23 |
Hey Roy,
Could you post how you wired up the gauge? It's obviously pretty simple, but there were three studs on the back of the gauge and I wasn't sure exactly how to hook it up. |
#24 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I found this thread by searching the forums for using the original ammeter space and replacing with a Voltmeter.
Good job on this. I had a bad dash fire back in 84/85 when I had my old 65 before. I'm going through the wiring now, and all evidence points to the ammeter.
#25 |
i did it kinda the same in my 60-63 gauge panel. wanted a vac gauge for the left side (my K10 has the vac brakes) but haven't found one yet that i liked. so i put a $9 volt gauge there temp. tack is an old dixo--didn't want a 8k but the price was right.
1961 chevy K10 my build is------------61K10 build |
