01-28-2011, 08:04 PM | #1 |
Leaf Springs To Trailing Arms ?
I have a 68 GMC with leafs, How difficult to swap to trailing arms ?
01-28-2011, 09:23 PM | #2 |
Happy to be here
Re: Leaf Springs To Trailing Arms ?
If you find a donor truck or buy the aftermaket parts its not too hard. Plan on spending a LOT of time getting all those rivets out if you use a donor truck.
01-28-2011, 09:30 PM | #3 |
Thanks for all the help guy's ?
01-28-2011, 10:24 PM | #4 |
A doner truck shouldn't be that hard to find around Lagrande. Your center crossmember should have the holes already in it for the brackets for the trailing arms to bolt to. They are riveted originally. One of the aftermarket suppliers sells the spring perches for the axle to mount your axle to the trailing arms or use the axle that came on the doner truck. Personally I always hated trailing arm suspension but that is just personal preference.
01-28-2011, 10:52 PM | #5 |
Retired Air Force Veteran
Did the swap from leafs to trailing arms about 3 years ago. Originally bought Axle Saddle Brackets from ECE but then was fortunate to pick up a 5 lug rear end and front spindles (Thanks Joe - ChevyChase) once all the brackets and hardware was obtained, my son and I finished it in a weekend.
Trailing Arms were bought at a swap meet 6 inch drop coils from GMC Pauls Super Track Bar from ECE Frame and Cross Member Brackets from different board members
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
01-28-2011, 11:26 PM | #6 |
When getting those rivets out I used hole saw cutters...there drill bit in diff sizes with a hollow center took me 15 min to remove 7 rivets I thinks that's a new record.
Posted via Mobile Device |
01-28-2011, 11:27 PM | #7 |
I did one just this summer, and was pretty straight forward. doner makes it easier but it is fun to fab your own stuff too.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
01-28-2011, 11:30 PM | #8 |
I can't load pics but snap-on makes them part #ga219b if someone could put up pics it would be great thanks......wok like a charm takes he heads right off
01-28-2011, 11:47 PM | #9 | |
http://buy1.snapon.com/catalog/item....4&group_ID=951
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 01-28-2011 at 11:48 PM. |
01-28-2011, 11:55 PM | #10 |
Yes sir those are it not trying to steel thread but dam did those save me time......I LOVE those bits......I would rec to all members maybe we should start a new these on theses?
01-29-2011, 12:46 AM | #11 |
I went and got me a donor truck and did a frame swap as I had it all apart I restored the Frame and everything I could that way.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
01-30-2011, 02:10 PM | #12 |
I wanted to thank everyone for the advise on the swap to trailing arms, going to do it when i can get to the truck, still have a foot or more of snow in front of the building its in right now, 29 and snowing again today.....
