01-31-2011, 01:55 PM | #1 |
whats the best valve cover gasket ?
I just changed my oil and I find my 4 dollar a quart oil is leaking out the valve cover on the drivers side WTF Im thinking I need a new gasket but what is the best value on gaskets and do I need to buy two or can I get them single, BTW it on a 307 sbc
1970 Custom camper 20 lwb 1978 yamaha xs1100 (insert clever quote here) |
01-31-2011, 02:37 PM | #2 |
Parts and more parts
Re: whats the best valve cover gasket ?
I would use a Felpro metal impregnated gasket, if it were me.
Frank |
01-31-2011, 03:47 PM | #3 |
That's what I use.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
01-31-2011, 03:49 PM | #4 |
Yep the steel reinforced Fel Pro is what I have had the best luck with.
01-31-2011, 03:58 PM | #5 |
talk about the can of worms you just opened... haha... if installed correctly the cork ones will work great...
but if you are planning on adjusting valves often or taking the covers off more than once or twice a year i'd go with the rubber ones like stated before..
https://www.ebay.com/itm/29620574751...mis&media=COPY |
01-31-2011, 04:25 PM | #6 |
Every set of rubber gaskets I ever used leaked. Cork have always worked best for me, but as stated above, they must be torqued correctly.
01-31-2011, 04:55 PM | #7 |
Felpro rubbers always worked GRRRRReat for me! Hmmm, just had a craving for cereal...
01-31-2011, 05:09 PM | #8 |
I just had a problem with my valves covers sealing. The covers are stock steel and as flat as a pancake but I still couldn't get them to seal. I finally got these felpros from Summit racing and no more leak!
http://www.summitracing.com/parts/FEL-1604/ |
01-31-2011, 06:45 PM | #9 |
I use the cheaper Felpro set and have had great luck with them. I retighten them ever so often as they settle but I haven't had a leak yet and it's been several months since the install.
-Scott- |
01-31-2011, 06:59 PM | #10 |
huh?
I've used Skip White's metal core rubber gaskets with success in the past. They even come with new (longer) studs too.
You can find them on eBay.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
02-04-2011, 04:04 AM | #11 |
I use the Edelbrock rubber ones that are fiber in the middle. I had to use the thick ones to get my valve covers to fit and not hit the intake. They work really well, but not everbody needs 5/16" thick gaskets.
02-04-2011, 04:49 AM | #12 |
I've tried both rubber and cork and had leaks but I'm also running cheapo covers. Finally bought the spreaders and that did the trick.
1972 K10 4wd Swb 350, 4 speed, 205 t-case Sold 1971 Cheyenne 2wd Lwb 350 4 speed Sold 1972 K5 blazer 4WD auto A/C |
02-05-2011, 10:21 AM | #13 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
02-04-2011, 11:44 AM | #14 |
Moderator
Use rubber gaskets. Cork is porous and WILL eventually leak.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 02-04-2011 at 11:46 AM. |
02-05-2011, 11:21 AM | #15 |
Change both and I used Felpro also get some ARP valve cover bolts and you are done...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
02-05-2011, 12:51 PM | #16 |
Man of Mini-Talents
A set of spreaders can help, but not much can overcome a cheap set of chrome covers.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
