01-31-2011, 02:01 PM | #1 |
Always a work in progress
Storing my truck for a year
What do I need to do in order to prepare my truck to be stored for a year? The motor will get replaced when I get back but I don't want it to seize up and I am going to rebuild the tranny before I put behind the 6.0l. It will be in my garage probably on jack stands so the tires don't go flat or out of round.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 Last edited by softballnrd27; 01-31-2011 at 02:02 PM. |
01-31-2011, 02:19 PM | #2 | |
Badass
Re: Storing my truck for a year
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
01-31-2011, 02:29 PM | #3 |
I saw an article once that said to drain all the fluids, spray the carb with WD-40 until it dies out and it said to do something to the hoses and belts but I can't remember now. It was pretty much like putting away a boat for the winter. You might be able to google that and find out more info. I found this.....
1. Wash the car thoroughly to remove any salt residue that may have accumulated from the roads and to remove any dirt from the paint. Clean and vacuum the inside of the car to remove any food that might attract pests. 2. Park the vehicle in a sealed environment like a closed shop, storage unit or garage. 3. Drain the oil, gas and cooling fluids with wrenches and a drain pan. All these fluids will break down when sitting for a long time and cause rust inside crucial car components. 4. Disconnect the battery cables from the car battery with pliers. 5. Jack the car up and place jack stands under each axle. This helps keep the weight off the tires and prevents dry rot. 6. Buy a car tarp or cover and snugly fit it over the entire car. 7. Place moth balls around the outside of the vehicle to deter rodents.
1993 Chevy Suburban 4X4 (Off duty driver) 2012 Chevy Impala SSV (Work Vehicle) 2008 Harley Road King (Play toy) |
01-31-2011, 02:33 PM | #4 |
I disagree with draining all the fluids....
Year old oil has to be better than moisture in the air...
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
01-31-2011, 02:36 PM | #5 |
I thought the same thing.....rather have old oil between the metal then nothing.
01-31-2011, 02:40 PM | #6 | |
But Found Her 25yrs Later!
Depending on the last time I changed the oil, I might change it out, and then run the vehicle long enough to coat the parts with the fresh oil.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 01-31-2011 at 02:41 PM. |
01-31-2011, 02:38 PM | #7 |
I would use a car cover rather than a tarp.
Especially if you're not sure all traces of moisture are out of every nook and cranny of the vehicle. A tarp will trap moisture under. I had an idea recently, but I don't know if it is a good one or not. I wonder how house wrap, similar to tyvek, would work? Tyvek allows moisture vapor to escape but doesn't allow moisture in.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 01-31-2011 at 02:42 PM. |
01-31-2011, 03:19 PM | #8 |
id keep the oil in it now during storage time but definitely change out the old oil when you are done storing and before starting back up
1986 LWB C-10 305/th400 Daily Driver and beer runner |
01-31-2011, 04:11 PM | #9 |
When I stored mine for a year I did all of the mentioned above, minus the car cover. Another thing you might consider is a paper plate filled w/ Arm & Hammer “baking soda”…..supposed to draw the moisture out of the air & helps keep the chance of mold down & from getting that musty smell, the plate’s usually placed somewhere in the floorboard area. I also capped my exhaust, but if you do that just remember to keep a “to-do” list inside the truck somewhere of everything you did so you don’t forget to undo anything.
01-31-2011, 04:21 PM | #10 | |
01-31-2011, 04:42 PM | #11 |
I've read for winterizing boats, it's recommended to keep the gas tank FULL and stabilize it to reduce/eliminate condensation of water.
01-31-2011, 05:07 PM | #12 |
I'm thinking I wouldn't drain the radiator either.
Once the water is out of the block, it now can breath oxygen which may allow for rust. I would fill it all the way with antifreeze, and then, when I pulled it out of storage, possibly drain and add fresh.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 01-31-2011 at 05:07 PM. |
01-31-2011, 06:37 PM | #13 |
I've always heard it's best to change the fluids right before a long storage, but never to drain & NOT re-fill.....having no oil/antifreeze in the block makes absolutely no sense to me whatsoever & I cannot think of what you'd be gaining by doing that. I'd never do it & I wouldn't recommend doing it either, but it's your truck & your decision I suppose.
01-31-2011, 11:26 PM | #14 |
Do it up with the moth balls, I think rats making a hotel out of your truck is the worst thing that could possibly happen.
