Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-01-2011, 12:16 AM   #1
onebadbowtie
onebadbowtie's Avatar
72/69 K10 project "Big Dreams"
Hey guys...thought i would go ahead and start a build thread. it will be a long slow process but maybe one day i will get it to where i want it. the frame of the truck is a 69 and the body is a 72. this is my second 67-72 chevy truck i got 72 c10 long bed when i was 14 as my first truck. i sold it when i was 15. ive wanted a 4x4 one ever since. im now 21 and finally have one. this will be a slow build due to me trying to get through college and all my other hobbies. Now to the truck
the body is a complete rust bucket.
but mechanically solid i drove it 2 hours home
it has a 355 and a granny low 4 speed
4 inch lift kit
35x12.5 goodyear wranglers
my main goal for the truck is a weekend driver to play and beat on so the rough body doesn't bother me much. i would like to completely restore the frame and drive-train then just put the old body back on and drive it
since i bought it i replaced the rubber brake lines from the frame to the front wheels
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 02-01-2011, 12:21 AM   #2
onebadbowtie
Re: 72/69 K10 project "Big Dreams"
this past weekend i got to work on it some more. the rear bumper was barely hanging on and the receiver hitch was mounted very sketchy so i removed them and some old exhaust brackets. the plan is to build my own bumper/receiver hitch. i think one of the leafs on the driver side might be broke because it leans really bad that way on the back what you guys think anything else that might cause this?
James
Old 02-01-2011, 01:36 AM   #3
chevyndn
it looks like the bed is what is leaning, not the truck.
chevyndn is offline   Reply With Quote
Old 02-01-2011, 05:23 PM   #4
onebadbowtie
took her out to play in the snow and now she is setting in the yard broke. i got stuck in a snow drift and went to back up. put it in reverse and let off the clutch and it jumped out of gear. the motor still runs good but the truck wont move. the clutch pedal goes to the floor and wont come up unless you pull it. and you can put it in any gear with the motor running and not pressing on the clutch. what did i break? and its not the drive shafts. it took us 3 hours to get it out and back in the yard
James
Old 02-01-2011, 06:55 PM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Cool truck! After you fix what you broke, I would just keep the truck the way it is and use it how you want. It is all the same color, and parts of it aren't falling off too bad. Nice score!
Ryan
1969 Chevy milk truck
Old 02-01-2011, 08:00 PM   #6
onebadbowtie
thanks man!
i havent messed with it since i pulled it in the drive. its -5 windchill and we have about 12 inches of snow right now. i hope it is an easy fix. i'm wore out form just getting it to where its at. we have another snow day tomorrow so might get it maneuvered into the shop. if not it will be the weekend before i can get a look at
James
Old 02-01-2011, 06:56 PM   #7
Dieselwrencher
Have you checked your clutch linkages and the clutch fork yet? Maybe the fork is bound up on the throw out bearing holding the pressure plate and causing your clutch pedal to not want to come back?
Ryan
Old 02-01-2011, 08:04 PM   #8
onebadbowtie
but if its just the clutch shouldn't i be able to shut the truck off and put it in gear and start it to make it go? cause that wont work...we already tried that and put the transfer case in all positions and wouldn't go that way either
James
Old 02-01-2011, 09:40 PM   #9
Dieselwrencher
If it is the clutch fork jammed on the throw out bearing the clutch may not release and you won't transfer any power through the clutch and you can't go anywhere.
Ryan
Old 02-01-2011, 10:13 PM   #10
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Welcome from another Kansas member. Did you just get that off of craigslist? I swear I had seen one in the past month just like that. Good luck with the truck. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-01-2011, 10:20 PM   #11
onebadbowtie
ya it was for sale on the topeka craigslist. i knew the kid and saw the ad after i bought it lol. he was asking 7000 for it...i paid 1200 for it.
James
Old 02-08-2011, 08:39 PM   #12
Dieselwrencher
You would be saving time for yourself just doing it all now. If you can swing it, that is what I'd do. You may not need front springs, but then again every one builds them, springs, differently and who knows which springs you really have on there now.
Ryan
Old 02-08-2011, 09:23 PM   #13
onebadbowtie
ya i will probably just save up and get the kit....hopefully my tax return will be enough... the kit is only like $615 or so from rough country but shipping is $85 so i'm going to go try to talking to a local shop because he is a rough country dealer and see what he can get me one for.
James
Old 02-09-2011, 08:32 PM   #14
onebadbowtie
School and work got canceled today so i got to do some more work on the truck.
Got the seat pulled out and floorboards all cleaned up. i sprayed the area under the seats and the hump with semi gloss black and the area where your feet go with primer. i plan on buying some of that bedliner in a rattle can to do the are for you feet.
I also started cleaning the area on the back of the frame rails where the previous owners welded on bumper brackets.
Fixed a minor gas leak also and cleaned all the snow and ice out from under neath it
James
Old 02-19-2011, 02:45 AM   #15
onebadbowtie
i got the bedliner sprayed on the floor boards yesterday and found a set of mirrors and got them installed also. pics to follow. im hoping to get it tagged sometime next week....keep my fingers crossed. also got my shackles in the mail but haven't got them installed yet. hopefully i will be getting my tax income money soon so i can get the new lift kit on order. the whole leaning thing really annoys me lol
James
Old 02-20-2011, 12:31 PM   #16
onebadbowtie
hear is the pics of the finished floor boards that have already been put to the test and the new mirrors with custom spacers aka old sockets lol
James
Old 03-22-2011, 12:48 AM   #17
vk_chevy
vk_chevy's Avatar
flatbed looks good,
72 Chevy C20 Longhorn
72 Chevy, K20 Custom Camper
67 Chevy, LWB, C20, 350/350, PS, PB,
65 Jag MKII
vk_chevy is offline   Reply With Quote
Old 03-22-2011, 01:05 AM   #18
onebadbowtie
Originally Posted by vk_chevy View Post
flatbed looks good,
thanks! i really appreciate the feedback
James
Old 03-22-2011, 01:31 AM   #19
Altec
Getcha Pull
Altec's Avatar
Bed have stake holes? Add some shallow stake sides and you have my wet dream for a farm/hauling truck! It is wide, but the extra room could come in handy.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 03-22-2011, 08:43 AM   #20
onebadbowtie
yes it does have stake holes...i plan on making some so i can deliver fire wood with it, but with the broken leaf springs cant haul anything yet. so stake sides are in line behind the new lift springs for now
James
Old 03-25-2011, 05:49 PM   #21
onebadbowtie
got the wiring finished up last night. took the ol girl on her first trip to town and filled her up with gas. put about 50 miles on her today. it was nice to actually get to drive it. me and my brother cut and hauled 3 ricks of wood today so i took a picture of it all loaded down
James
Old 03-25-2011, 06:03 PM   #22
Gene
Gene's Avatar
Flatbed looks pretty tough! I would shorten it though. Cool truck.
Gene is offline   Reply With Quote
Old 03-25-2011, 11:13 PM   #23
onebadbowtie
Thanks! and ya shortening it is definitely on the todo list. You have super nice truck btw and i can't wait to see it done
James
Old 03-27-2011, 06:14 PM   #24
onebadbowtie
i fabbed and installed some custom tow hooks today. i think they turned out good! i also changed out the front shackles that where some homemade job and put factory ones back in.
now the pics
James
Old 03-27-2011, 09:34 PM   #25
Gene
Gene's Avatar
Thanks, kinda hit a roadblock when I ran outta money. Been fixin wiring glitches here lately after I got it running.
