Old 02-01-2011, 08:31 PM   #1
Benelli
Watchin the rust grow
Benelli's Avatar
Need some cold start help
It was -20F below zero when I took this video. Is this normal or is there something else wrong? The windchill was at -40 and the grill was facing into the wind.
Stats of the truck are in the sig, pleae let me know whats goin on here. I was worried!
http://www.youtube.com/embed/vMbje4TYlo0
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 02-01-2011, 08:54 PM   #2
chevymotocross
chevymotocross's Avatar
Re: Need some cold start help
When it's that cold..... carbs just aren't going to work like they did when it's say 50 degrees out.
Is your choke adjusted properly?
Last carbureted vehicle I had was a F*$D with a built 351m. I was always late to school on the COLD winter mornings.
I love tbi :-)
But seriously, first thing is to make sure the choke is working properly.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 02-01-2011, 08:57 PM   #3
Goldfinger
Goldfinger's Avatar
Even in Florida at 20 degrees mine will have a little of that. Just press it down halfway and release then when it fires barely touch the gas. Make sure your choke engages as well my old Rochester had a faulty auto choke and it did this much worse until you stuck a screwdriver to engage the choke.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 02-01-2011, 09:11 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Adjust the choke to stay closed longer. Aluminum intake and carb don't help either. Hi humidity will freeze at the needles. Carbs just don't like cold.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-01-2011, 11:24 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
starts like mine lol
i got a holley avenger too and a Edelbrock intake
sounds like it needs more gas
my choke works after it stalls the first time
but i'm still workin out those bugs
sounds like the line goes empty and yer suckin all the way from the tank
or dam near
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 02-01-2011, 11:54 PM   #6
silverbullet01
if its cold pump it.. kinda sounded to me like it was flooded.. pump it some, or hold her wide open and roll it, if it is flooded..
silverbullet01 is offline   Reply With Quote
Old 02-02-2011, 02:22 AM   #7
gchemist
gchemist's Avatar
BTW - never rev a cold engine!! Oil is not moving properly. You can cause wear on parts!! You can also drop oil weight for the winter. I would not go down past 10 - 20.
Old 02-02-2011, 02:48 AM   #8
MTCK
MTCK's Avatar
What gchemist said. Not much oil wandering around the top of the engine... Either too much fuel or not enough... Hard to say, the exhaust was pretty dark but it sounded starved to me. I always would give my carbed trucks about three good pumps when it was really cold and hold 1/2 throttle. It would crank fire and die. Then start up on the second crank. Those were all quadrapukes though. I too love TBI, but a carb with a properly adjusted choke can work just fine. -20 is pretty cold without plugging in. Mine will start like it's 0 at -40 when plugged in. Block heater, oil pan heater, battery blanket and tranny pan (on the autos) heater. Good luck.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
