02-01-2011, 11:14 PM | #1 |
Lucky Teter at the wheel
Type of front bags
I am wondering why the front bags on all kits have to be the fat bellows type. You have to put a plate at the top so the bag can't go up into the spring pocket. Why no do a rolling sleeve type bag and mount it up in where the spring used to reside?
I am looking for a softer smoother ride more than I am wanting to drag the ground. Any insight would be appreciated.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
02-02-2011, 12:23 AM | #2 |
Re: Type of front bags
Sleeve bags are designed to move straight up and down, not working on a pivot like your front end operates.
02-02-2011, 12:43 AM | #3 |
Really? Not possible? That's a bummer.
02-02-2011, 03:33 AM | #4 |
Stalker Nate
What MK said....no can do
Smoother and softer ride? Have you rode in a bag'd truck before? It's not a stiff ride. My bag'd S10 rode great actually. Just depends on the bags you buy. Size and brand does make a different in ride quality. Having shocks and a sway bar will also change how it rides of course.
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
02-02-2011, 12:16 PM | #5 |
Softer & smoother ride vs. what?
02-02-2011, 05:26 PM | #6 |
I think he might mean that everyone talks about how sleeved bags ride in the rear way better than a double convo when it's set up one to one / directly over the axle. With hearing that thinking "so if they are better in the rear, why not better in the front"? I can see the misunderstanding for sure if you're not familiar with air suspension.
I'm not speaking for him, that's just what came to mind. |
02-02-2011, 12:39 PM | #7 |
When I first bagged my '69, I was blown away at how well it rode. Good shocks, proper bag pressure, and it will ride like a dream.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
02-02-2011, 09:26 PM | #8 |
Not to highjack, but im trying to figure out a lot about air bags right now too. I have a '59 Apache with a '79 Camaro sub frame. Will I get as good of a ride out of bagging the front as I would stock? I want to leave the sway bar on. I also want to be able to have it up at the factory ride height or close to it. I'd like some adjustability though.
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
02-02-2011, 11:51 PM | #9 | |
02-03-2011, 12:42 AM | #10 |
I have RE7 bags on the front of my truck, and my truck has a very comfortable overall ride.
02-05-2011, 12:36 AM | #11 |
Thanks for all of the replies. MKcustums is exactly what I was thinking, I heard sleeves rode smoother. Since I can't run those up front, which convoluted bag would be the smoothest? I understand biggest volume helps here. All of this is going on a 2001 frame which will have a 1972 Crew Cab sitting on top. (Young Frankenstein build). Because of my wheel tire combo and body mounting issues, I am not planning on lowering the truck much at all. All of the bag mounting kits give you a huge drop which won't work for me. I guess I will have to fab my own brackets, any ideas?
02-05-2011, 12:45 AM | #12 | |
02-05-2011, 02:04 AM | #13 |
Stalker Nate
Honestly, if you want to run stock height or within 2" at ALL times and never lower the truck past the 2" mark I wouldn't run bags up front. It's be a waste of money and your ride wouldn't be any better than running static suspension. You're better off just running some nice 1-2" drop coils with good shocks if you plan on staying close to factory height all the time. Just my opinion though. I wouldn't do bags if that's your plan and the restrictions you have on the frontend height.
