02-02-2011, 12:30 AM | #1 |
Air bag kit for 2nd gen camaro subframe?
Im looking for an economical air bag kit for just the front of the '59 w/ a '79 camaro subframe. any thoughts?
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
02-02-2011, 12:40 AM | #2 |
Re: Air bag kit for 2nd gen camaro subframe?
Would something like this work?
http://www.auto-addicts.com/product_p/baga-25aaaa.htm I dont need a compressor. I have some 2,200 psi air bottles that I can easily refill. I was thinking that a hidden dial regulator like what you would use to adjust the output pressure for your air compressor would work. I dont want "switches" in the cab. What do you guys do? I would think that I could make something instead of buying these: http://www.auto-addicts.com/ProductD...F7081&CartID=1
02-02-2011, 07:12 AM | #3 | |
Old Heap Driver
My 73 C-10 is bagged and the 50 I'm building will be bagged. I wouldn't run air ride without switches in the cab. I've had friends that started out with tanks and eventually went with on board compressors. If you develop a leak you'll need air asap.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
02-02-2011, 01:33 PM | #4 |
That makes sense. Do you have pics of the neccessary trimming by chance? Maybe I will start with the high pressure air bottles and move to a compressor later. Are those bags acceptable for using on a camaro? I want to be able to air it out to the bump stops and be able to inflate it to normal stock ride height. Im a total noob when it comes to air bags. Thanks for the help guys!
02-02-2011, 08:31 PM | #5 |
Old Heap Driver
Those bags look OK but I've not heard of the brand.
As far as cutting the spring tower.....I'll try and get some pictures this weekend of my S-10 chassis to give you a general idea. My setup will be using the same style bag cups, I'll get you some pics of those as well.
02-02-2011, 09:03 PM | #6 |
Ok, I am going to give making my own brackets a whirl. I ordered two each of the upper and lower universal brackets. I'll need to pick up some 5.5" tubing/pipe to weld onto the upper to space it down. I would REALLY appreciate some pictures to help guide me along! I want to be able to get it up to the factory-ish camaro height, as well as drop it down. Here are a couple of other bags I was looking at:
Slam Specialties RE Series 5" Air Bag Single Port 200psi Sale Price $85.00 5.5" Diameter. 2.9" Collapsed Height 8.0" Extended Height -or- Slam Specialties RE Series 6" Air Bag Single Port 200psi Sale Price $85.00 6" Diameter. 2.9" Collapsed Height 10.0" Extended Height I was leaning toward the 6" bag since its extended height is a couple of inches taller. I want to be able to get it up to the normal ride height of the camaro suspension. Thanks a bunch! Nik
02-02-2011, 09:37 PM | #7 |
Good info! thank you! I see what needs to be cut now. Looks like quite a bit of work! haha. I better get on it! I wanna start working on a GTO project one of these days!
02-02-2011, 10:20 PM | #8 |
Yellow truck club
over in the suspension forum there are a few guys offering deals right now
here is one http://67-72chevytrucks.com/vboard/s...d.php?t=440242 AVS Jason is a nother one
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited Last edited by entourageguy; 02-02-2011 at 10:22 PM. |
02-02-2011, 11:29 PM | #9 |
Thank you. I found that earlier after posting this. I actually have spoken with Jason today and will get all set up from him. Thanks!
10-01-2011, 08:06 PM | #10 |
I HAVE PICS OF MY BAGGED 57 IN MY BUILD THREAD IN THE " PROJECTS AND BUILDS SECTION, http://67-72chevytrucks.com/vboard/s...d.php?t=484701 HOPE THEY HELP., oops sorry for the caps.
Learn to deal with reality, or reality will deal with you. |
